Oct-21-2018 11:32 AM
Oct-21-2018 01:49 PM
Janss wrote:
In the wide open landscape of the Southwest (excluding southern CA), sunrise and sunset are the most beautiful, magical times due to the lighting on the rocky outcroppings, canyon walls, etc. For this reason I recommend staying inside or as close as possible to the Parks. Check out Trailer Village inside Grand Canyon NP, Ruby's just outside Bryce, Goulding's just across the highway from Monument Valley...to get you started. Also check www.rvparkreviews.com
Expect CA coast campgrounds to be quite expensive.
Make reservations! These Parks and other areas in the Southwest are very busy in the summer!
There are soooo many other sights to add to your list. Have a look at grandcircle.org.
Be sure to know the pet rules at the Nat'l Parks...like dogs not allowed on trails.
Do you have an America The Beautiful Pass?
Oct-21-2018 01:25 PM
Oct-21-2018 12:48 PM
RGar974417 wrote:
When we went to the Grand Canyon,we stayed at Circle Pines KOA near Williams. Full hookups ,an indoor pool and hot tubs. Can't make any other reccomendations because we usually prefer campgrounds that are scenic with private sites.The ones we like to stay at are either no hookups or just electric.
Oct-21-2018 12:47 PM
NMDriver2 wrote:
WARM Pacific waters are not to be found in San Diego or anywhere in CA 🙂 You can swim in the ocean but a summer wet suit is recommended even in Aug. As far as full hook-up coast campgrounds go I would look at https://missionbayrvresort.com/
Warm Pacific waters as compared to Northern Atlantic waters!!! Hopefully anyway. Thanks for the info. I will check it out.
If you are going to Roswell, NM (http://www.redbarnrvparkroswellnm.com/) you might as well drop down to Carlsbad Caverns and hit White Sands Nat. Monument as you pass by.
Great info and ideas.
I hope you are planning a spring trip to avoid the 100+ temps you will find around Roswell in summer.
Oct-21-2018 12:39 PM
Oct-21-2018 11:41 AM
