Cross Country Planning in Late March / Early April 2017
GreenSalsa
Quick question,
Generally speaking, how open is the interstate road system going from eastern North Carolina to Seattle Washington in late March to mid April?
Is I90 / I94 generally trafficable with a 43 ft Motorhome?
I don't want to add on all the extra miles, but should I keep south along I40 and come up I5?
What other routes would you recommend? I am time restricted to 7-8 days for driving...
Just doing some planning.
Thanks
GreenSalsa lives in North Carolina, but dreams of life on the road...
3 REPLIES 3
2gypsies1
The last week of April one year I-40 just west of Albuquerque was closed for a day because of a snow storm. Many of us stayed right on the interstate unable to move.
You can't count on the weather. If you have a good forecast to take a northern route go for it. If you run into bad weather you'll just have to stay put until the highways are clear. If driving in snow/ice in the West chains will be required so best to just stay put until clear. Add in extra days for your trip. Good luck!
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
tatest
For long trips on a diagonal I plan a "preferred" route then modify it to adjust to short term weather forecasts and reports of road conditions.
For example, past 35 years we've been doing winter trips (home for Christmas) to southern Michigan. The shortest fastest route is I-44 to St Louis, I-55 to I-80, then I-94 into Michigan. But day to day conditions can make some part of that unusable, and there are dozens of alternatives for different sections, like going I-35 north Through KC to DesMoines to get around problems in southern Missouri or central Illinois, or taking I-70 from St Louis to Indianapolis to avoid a storm in northern Illinois, I-70 to I-75 to go through Ohio because northern Indiana is messed up. I've even gotten as far as Chicago before diverting to I-80/90 toll roads to avoid a lake effect storm in western Michigan, and once went as far south as Memphis coming back home because everything further north was shut down west of I-57. A lot of times my strategy was to travel north-south behind a storm, delay driving through it, and certainly to avoid staying in the storm system to be running its full north-south length.
If I get off the Interstates to use the trunk highways, the number of alternate routes approach hundreds. We don't have the high density of Interstate routes you enjoy in the East, but our trunk highways tend to be almost as good and less heavily traveled.
For your trip I-90 out of Albert Lea is probably the fastest route, I-94 out of Chicago costs very little extra time (and connects back to 90 to cross all the western mountain ranges). Taking I-70 out of Indianapolis to Kansas City, then I-29 to connect with I-80 to Salt Lake City, then I-84 and I-82 into Washington adds about an hour to the trip (42 vs 41 hours driving time).
That's a choice of three Interstates across the northern plains, and two choices to cross the Rockies with little difference in travel time. You make your choices based on weather forecasts or known hazards (e.g. you don't want to cross North Dakota if the Red River is flooding, you don't want to use I-80 if there are late blizzards in Wyoming). All cross the Cascades on the same route, I don't know the weather risks for that; I think it is snow chains country.
There are three other Interstate crossings: I-80 crossing the Sierra Nevada into central California (reached from I-70 or I-80, two different Rockies crossings) or I-40 to Bakersfield and up I-5, or I-20/I-10 into Los Angeles. This most southern route has the least problems with winter weather but is at least a full day's extra driving. I-40 is usually through with winter by late March, and getting into the spring thunderstorm season. I-70 and I-80 can still have winter weather, which is why we watch the forecasts for travel.
Tom Test
Itasca Spirit 29B
donkeydew
plan both ways and let the weather dictate the route.
with the screwy weather anymore if i had to choose one right now i would
the southern route to be safe.
