Date Sensitive Lukeville Temperature Warning
MEXICOWANDERER
A cut and paste...
"With up to 122 on the horizon, Palm Springs will have cooling centers in community centers and libraries, and Phoenix and nonprofit groups are planning water stations to help the homeless and others.
Palm Springs has soared above 120 several times, most recently hitting 122 on June 29, 2013.
The National Weather Service in Phoenix said the last time the temperature topped 120 was 1995, at 121. The record high is 122 degrees, set on June 26, 1990.
In the Arizona desert near the U.S.-Mexico border, the heat can be so deadly that the Border Patrol reassigns agents and resources to areas that are especially dangerous for immigrants"
This is no joke. Temperatures in the 120's are dangerous. I would be sorely tempted to not travel until the heat wave subsides. My toad air conditioner fought hard to reduce temperature from 122F to 111F. Exterior metal so hot it burned to touch it. intolerable screaming pain to roll down window because of blast-furnace temps. Like aiming a hair dryer at your arm at 18" distance. When I reached Laughlin, NV the temperature was 104F at five minutes past midnight.
29 REPLIES 29
MEXICOWANDERER
Persuing this a bit...
The heatwave hit while I was coming north. It was the 5th day with zero warning.
Hermosillo, Sonora has a 1st tier IMSS Hospital. I've been there. I have also been to Scripps Medical Center in Chula Vista, CA. The comment about "having everything" raises my eyebrows. Scripps, has over 40 Electrocardiogram machines and three MRI and seven Cat Scans. Hence no week long waits.
A space blanket to deflect radiant heat plus a large sheet of cheesecloth plus lots and lots of water (like 10 gallons worth) would prove most useful I would believe. The swamp cooler thermometers at the CBP swamp cooler were registering 116F in (in the shade) and 97F output.
Soaking the cheesecloth and wrapping it around me would have helped. Use the space blanket as shade.
Moishe. The first time I encountered 122F was in Cd Obregon Sonora in 1987. My bus had three roof air units going and I feared for engine and tire temps. I holed up in a forty-five dollar a night hotel. in a room on the ground floor on the east side. I actually sat against the large wall unit. I have never known three consecutive years in my life when the climate was not changing.
sonora
mexicoruss wrote:
We were in Needles all last week but had to come home to Penasco today. We planned accordingly for the almost 7 hour drive and left at 4 am getting us across the hottest part of the desert before it really heated up. When we hit El Golfo de Santa Clara Sonora the sea breeze was actually nice and we got home with no mechanical breakdowns due to the heat. Always carry lots of water when in the desert. Oh and Mike I didn't know you liked golf.....
I have many secrets. lol
qtla9111
It's been over 40C here in Monterrey for over a week and it isn't letting up. We are fortunate that our municipality was able to negotiate a lower electric rate from the CFE for our area.
A/C is on but not the whole house, just in one room at a time and the preference is the bedroom which has the smallest and most efficient mini split.
We had a power outage this afternoon but it only lastest 30 minutes and extended through different parts of 15 municipalities. I checked on line and it appears it is happening all around North America.
2005 Dodge Durango Hemi
2008 Funfinder 230DS
Living and Boondocking Mexico Blog
mexicoruss
Almot understands
Russ Black
011-521-638-113-4591 Cell Phone
Puerto Penasco, Sonora
bighatnohorse
mexicoruss wrote:
Since we are poor Mexican Americans we can only visit our daughter whenever we want (sarc on), she happens to live in Needles, we happen to live in Mexico. We have always lived in the desert and know how to travel. We would never think of going to AZ or CA for medical as we have it all here but thanks for your input, we spent a week up in CA with our daughter an d all was great, we had no schedule, we could have come home earlier or much later had we decided. We chose to come home to conduct business for our next year schedule for RV tours to Mexico. Your insight was entertaining but not that helpful.
I didn't understand that at all and assume it must be a "dig" at someone.
However, I did see that it was 123° in Needles - several degrees hotter than Phoenix.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
mexicoruss
Almot wrote:
There is no breeze in Arizona desert.
I understand that Mex is not a tourist. For Mexicans and expats living on the same level, trips North are usually something of necessity, doctors appointments etc. Schedule is tight and so is the budget. When you have to go, you have to go. Max distance is to be covered in a short time, additional stops in camps or hotels on the way aren't always desirable. The hottest I've been in, was upper 90s, 120F must be deadly.
Russ Black
Almot
mexicoruss
Russ Black
moisheh
These must be fake news posts as a certain person states that climate change is a hoax.
Moisheh
pianotuna
Nomad III
Nomad III
Hi Mex,
Why did you not turn back? It is frightening. Thanks for sharing this information.
MEXICOWANDERER wrote:
Between the border patrol checkpoint, and I-8, the temperature on 08/11/2011 actually increased from 122F. i could not believe it. The sun coming through the driver side window was so hot it was burning my arm. The toad engine temp was one needle width from "H"
I feared for the toad's tires. I reduced speed to 45 MPH (converter lockup), and prayed. Not one single vehicle seen for 50+ miles. If the car quit, there is little doubt I would have died.
This all sounds amusing until a person is hip deep in it. I carried 7-1/2 gallons of water and a Home Depot spray bottle. Spraying water into the radiator cooled engine temps to between the operating temp sweep line and H on the engine temp.
I will never do that again. No way.
Regards, Don
Naio
Gah, that sounds horrible. And scary.
Crossing the Mohave last year, my van AC at max kept the interior at 105 degrees. Cats do not like wind, but mine eventually came around to the goodness of water on the fur plus usb fan. I alternated him and me.
I was with a competent human friend and there were towns along the well-traveled route. Very different.
It was a hot year. We waited for the coolest day! It was maybe 110 outside. Not 120.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
dtappy3353
Thanks Mex for sharing your personal experience! Awesome information for all of us!!!
MEXICOWANDERER
pianotuna
Nomad III
Nomad III
Worst I've been in was 117. I started running the roof air from a generator as I was driving in a class C.
Regards, Don
sonora
It's 77 and over cast here right now in Wisconsin. PERFECT weather for the US Open which is 10 miles from my house.
