โApr-28-2021 02:58 PM
โApr-30-2021 11:04 AM
cptqueeg wrote:curt12914 wrote:
If you anticipate a trip that may go over your preset amount, you can go in to the EZ Pass website and do a one time payment, up to $3000. According to the website, the "New balance will be effective in 24 hours."
The penalty is too high to count on their system despite their assurances.
โApr-30-2021 08:05 AM
lenr wrote:
Many, many, of the states have monthly service charges for their EZ-Pass accounts, including NY the last time I checked. That service charge month in and month out could easily offset the RV discount for using a NY transponder. The Central Florida Expressway offers the Uni-Pass which works in 18 EZ-Pass states and most toll bridges in the Eastern US. You can buy one off Amazon and then set up a linked account with CFX. It has NO service charge!!! You give them a charge card to draw from and an amount to trigger a refill of your account. Simple. You can also register your tow vehicle and trailer plates--some states bill by plate if you have no transponder. I have done all this and it worked just fine in FL and the River-Link bridges in Louisville.
I believe both CFX and Sun-pass (FL turnpike) say to only use one transponder and they will count the axles. They warn that you may get double charged if you use two transponders. Personally, which, I've done, is to get one Uni-Pass and let the states figure it out--I'll bet the axle count will be correct or less than they should have been.
โApr-30-2021 07:57 AM
cptqueeg wrote:
One of the biggest downfalls of the NY Ezpass and perhaps others is the delay in replenishing your account. Typically it takes a minimum of 48 hours for a cc deposit to become available for use, although the instant the request is made the CC company credits them. This can be an expensive mistake if you drive from say NYC to DC in one day with the number of toll bridges and toll roads if your account is low to begin with. If there is a big toll day ahead always check on your account on line and make a 1 time payment to cover your planned tolls at least 48 hours in advance. Typically your account holds a very low amount like $25 and of course an even lower threshold to trigger the call for replenishment.
I found it advantageous to have multiple transponders; one for the truck and another for truck and trailer combo. It's been quite a while since I've towed so perhaps it's not necessary any longer. In those days NYS Thruway and MBTA each had its own passes.
โApr-30-2021 07:39 AM
curt12914 wrote:
I am thinking seriously of getting a
Uni-Pass to replace my EZ Pass. It is accepted in all states EZ Pass is, plus Georgia and Florida.
โApr-30-2021 06:53 AM
โApr-30-2021 06:39 AM
โApr-30-2021 04:22 AM
โApr-29-2021 09:44 PM
โApr-29-2021 06:53 PM
โApr-29-2021 05:43 PM
โApr-29-2021 09:15 AM
toedtoes wrote:
I found this article online: towing and ez pass
For a standard hitch trailer, it appears that you can use the standard pass and the system will account for the proper number of axles and height as you go through.
If you have a 5th wheel or motorhome, you want to get the towing pass because you get a toll discount. If you use the standard pass, you will not get that toll discount.
โApr-29-2021 08:35 AM
โApr-29-2021 07:17 AM
Sjm9911 wrote:
In nj, they said only the one tag. It counts the axels. I have used it in ny and pa with no problems with 2 different axel campers.
โApr-29-2021 06:52 AM
