Rough bridge on 95, southern VA
Bill1374
Just filed a request with Virginia DOT to do something with the bridge on 95 northbound, I think around Skippers. Bounced my trailer so bad, it tipped the table over. Concrete surface is mounded between the expansion joints and really causes the trailer to bounce, almost had the wheels off the road at one point.
Couldn't remember the mile marker but the bridge sits in a dip and there's an exit just past the bridge. Be interesting so see if anything gets done. Did get a response acknowledging the submission.
Bill
KZ Montego Bay in Florida
Rockwood lite up north
2016 HD Street Glide, 12 Fatboy for cruisin
10 REPLIES 10
bucky
Before a friend retired from VDOT, he told me that they could create standing water on a hill without trying. ๐Ÿ™‚
Puma 30RKSS
Taco
I know exactly which bridge you are talking about. Towing across it really makes you notice the bumps.
Sailordive
Bill1374 wrote:
You're right, bukhrn, it's well below Emporia and it is the northbound side. It will be interesting to see what response if any I get from the DOT. See the new paving going down on 95 through Richmond now, and that was sorely needed.
Bill
We hit it in the sports car Thanksgiving day and it was a good hundred yards before the car stopped bouncing.
2013 Sportsmobile Sprinter
bukhrn
Bill
If you get a favorable answer, you'll be doing better than us Virginians get. ๐Ÿ˜‰
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
Bill1374
Bill
bukhrn
JamesBr wrote:
Sounds like one of the ones on the south side of Richmond, its one of the reasons I prefer to take 295 to avoid that section of I95.
That is one,(of many in the area) but the one OP is talking about is down below Emporia.
2014 Ford Focus
Lorne_Lorraine
I have these points set in my GPS to warn me a bit in advance of this rough bridge. It can really get my Class B bucking crazily even with new shocks. I slow down a LOT which keeps the bucking within reason. Can really surprise you the first time. You can bypass on Route 301 past the Yogi Bear campground at Emporia (run 301 between I95 Exits 11 and 17 I believe).
Rough Bridge SB I95........N36.76492 W77.48450
Rough Bridge NB I95........N36.76244 W77.49282
Lorne Ross
2003 Pleasure-Way Ford Excel TD
Camped the lower 48 states and 9 provinces
Most multiple times and now on the repeat!
JamesBr
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
Bill1374
That's the one! Wish there was a way around that thing. Doesn't make a difference which lane you use either.
pa_traveler
Might be same place that throws truck into severe bucking ,I hit it last two times on 95.I was thinking this is going to cause an accident.
