Aug-23-2021 08:39 AM
Sep-25-2021 04:13 PM
Aug-24-2021 11:58 AM
Aug-24-2021 10:03 AM
jkwilson wrote:Great suggestion, thanks. Works everywhere in New England except VT and CT, correct?
Roads in New England tend to be insane on Friday and Sunday as weekend traffic heads out from and back to the cities. The closer you get to the ocean, the worse it gets.
If you don’t already have an EZPass, consider it. It’s hard to avoid the toll roads out there.
Aug-24-2021 09:51 AM
DrewE wrote:Thanks, DrewE!
365 and 8 and 9N are all decent roads--not glass smooth, of course, but not by any means what I would consider rough. 17 is generally fine in terms of not having particularly rough pavement etc. as well, even through the Appalachian Gap; while the road may be a bit rough, it matters a good bit less when you're going 20 mph or so instead of 50...and towards the top of the gap, that's what you'd be doing. Like I wrote before, I would generally not recommend the Appalachian Gap for RVs, even though it is safely doable with proper care.
US2 and US302 I'd expect to generally be in fairly decent repair, but I don't travel them too frequently and so can't be specific there. They're rather important secondary truck routes (US2 in particular), and so kept in pretty good repair. Naturally there will be some areas better than others, and quite likely a few spots of construction along the way. The Kancamagus Highway was in very nice condition the last time I drove it, too.
Aug-24-2021 06:30 AM
Aug-23-2021 07:20 PM
Aug-23-2021 04:58 PM
Crowe wrote:Thanks for the info. We've made a number of calls to campgrounds throughout NE. Weekdays look promising, but, as you said, weekends will likely be hit or miss. We may be forced to seek out a Walmart (or equivalent) on the weekends.
I would check in advance to make sure there's availability. Some school systems have already to started so mid-week shouldn't be much of an issue but weekends might be. Acadia in ME, Mt. Washington/N. Conway in the White Mountains. Keep in mind you may have difficulty crossing back into the US if you go the Canadian route.
Aug-23-2021 04:15 PM
Aug-23-2021 03:56 PM
I may not have gone where I intended to go, but I think I have ended up where I needed to be
Douglas AdamsAug-23-2021 12:55 PM
Aug-23-2021 10:39 AM
Aug-23-2021 09:51 AM
Aug-23-2021 09:38 AM
