Jan-24-2021 08:55 AM
Jan-25-2021 04:20 PM
Minnie80525 wrote:wanderingaimlessly wrote:
Do you need the anti sway/wd bars for back roads towing? Why not take them off?
I could do that, sure. It's a pain, though, not only having to stop and jack-up the hitch, but also to stow the greasy bars. Every obvious option is already occupied.
Jan-25-2021 02:20 PM
Jan-25-2021 02:02 PM
Jan-25-2021 01:47 PM
wopachop wrote:
Are you sure removing the spring bars and storing them away is necessary?
Jan-25-2021 01:30 PM
Jan-25-2021 01:06 PM
Jan-25-2021 12:16 PM
Jan-25-2021 09:19 AM
Jan-25-2021 08:50 AM
SteveAE wrote:
All,
I can not comment about other hitch types, but I have confirmed with Hensley that there is no need to reduce bar tension in rough conditions.
It can be reduced or left as tight as when on paved roads and there will be no damage either way. Best wishes to the OP in finding the correct answer to his question.
Jan-25-2021 06:17 AM
Jan-25-2021 02:50 AM
agesilaus wrote:Something like this mounted to the a-frame should do the trick:
I have my doubts about that, the fastaway bars, at least on our hitch are rectangular and heavy. Maybe 8 or 10 pounds. Your welding shop idea is workable but I don't get the problem with dropping them in the bed of the truck. If his are coated with grease then he is doing something wrong. Fastaway recommend lube only at the contact points. The ends of the bar. Carry a rag or two and wipe it off.
Fastaway e2
Jan-24-2021 11:56 PM
Jan-24-2021 08:57 PM
Jan-24-2021 07:44 PM
Jan-24-2021 07:14 PM
wopachop wrote:orSteveAE wrote:Too much bendy on the metal bars. Leaving them attached is somewhat foolish if youre driving slow over rough terrain. Kinda depends. Think of a jeep with the sway bars attached.
So I would greatly appreciate it if someone could school me on where, when, and why you would want to do this? Then, perhaps after this education, I will become braver (or "more foolish") at dragging my trailer through even rougher terrain
