Directv Locals in Yuma, Az
Me_Again
Do you get Phoenix locals on Directv if you use a Phoenix area Zip code??? Chris
16 REPLIES 16
FlatBroke
BarbaraOK wrote:
Even better, get DNS service and watch the ABC, CBS, etc., from either New York or LA (depending upon your billing address). Then you never have to switch and if you are really desperate for local fire/murder/traffic accident news you can use your antenna.
Barb
Yeah, use to do that but then it was $15 a month. Then you get NY or LA garbage and not the area garbage you are living in. A simple 2 minute call to the Directv moving phone number and asking for a seasonal address change is FREE and no messing with the OTA.
Hitch Hiker
"08" 29.5 FKTG LS
vegasken34
After a lot of hassles with Directv agents, one told me that the key was to tell
who ever you get that you wanted to change your PHYSICAL address. Since then no problems when ever we moved or how often.
CA_Traveler
CA Traveler wrote:
gatorcq wrote:
Direct TV broadcasts in SD and HD for the Phoenix locales. So the satellite antenna will not matter.
The spot beam map for Phoenix, shows you can get it all the way to San Diego.
The signal gets weaker as you travel away from the center of the spot beam. So the type of antenna which includes it's size does matter.
The spot beam map shows significant reduction in signal strength for SD. I'll be in Oceanside just north of SD in two weeks and will see my full array dish picks up the Phoenix locals.
I'm in Oceanside and can't get Phoenix locals on my full array dish.
2014 Grand Cherokee Overland
Bob
Retiredblade
I don't know about all this switching, I had my wingard traveler switched on before leaving home, got to S.C. called them, they wanted the zip where I was so I could get local channels, did so and got them. The fellow said, when you get to where your going, I'll have to call with the zip so I can get local channels. Nuts! I got to where I was going, got set up, turned it on and picks up all the local channels without calling and giving them the zip, seems the blind are leading the blind over at Dish.
C-Bears
Me Again wrote:
C-Bears, Directv policy seems to allow the two switches a year without a problem. More can be and issue with them. Dish is reported as easier on this. I just say I am at my winter location. Please switch service address. Billing is electronic and payment automagic, so that is not an issue.
Chris
You are probably correct about 2 switches per year before they start freaking out. We used to have a Direct TV dish at our boat dock on Lake Michigan. We would have them switch it to our "summer" home 2 or 3 times every summer and they never questioned it.
We have found while traveling we do great on the antenna for local channels. Since we are only at two different locations each year long term it is working out now just switching twice.
2014 Montana 3725RL (Goodyear G614 Tires, Flow Thru TPMS)
SPENDING THE WINTERS AT OUR HOME IN SW FLORIDA. THE REST OF THE YEAR SEEING THE U.S. FROM OUR LIVING ROOM WINDOW!
Me_Again
Chris
BarbaraOK
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) ๐Ÿ™‚
2018 Ford C-Max HYBRID
[purple]FMCA - F337834, SKP #90761[/purple]
Our Blog
C-Bears
The first year of traveling with the Wineguard Travler Dish on top of our fiver we called Direct-TV every few days and had them switch us. We soon learned that is not the way to go.
Sometimes we would get a customer service rep that just could not understand and insist on switching our "billing" address. Another time the service rep had to go find a supervisor because he thought we should be charged for switching locations. Even had one ask the definition of a 5th wheel. When she did not understand what that was I tried to explain it as an Recreational Vehicle and she never understood that either.
Needless to say we only switch twice a year now. Once when we get to central Illinois for a 2 or 3 month summer visit and when we get to Florida for a 4 month stay.
For local channels while traveling the other 5 or 6 months we use our antenna.
Me_Again
Well I know how to get Directv to switch addresses as we spent 5 winter in the East valley. Last year we stayed home and this year we are going on a 1 month exporing trip to Hemet, Yuma, Mesa and Gold Canyon(home away from home). We have a Slimline SWM HD dish and will call at Hemet and just see how it goes for there. Thanks Chris
RoyB
oops decided my answer was way out in left field...
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
CA_Traveler
Different satellites transmit DTV SD and HD and the spot beams are not the same. I can get SF HD locals up to the OR border and SF SD locals up to the WA border.
Bob
CA_Traveler
Bob
beliveauj
Call in and change your service address to a rv park in phoenix.Thats what I did last year in Yuma.
Jim & Jeanne fulltiming and loving it.
Buddy and Emma (Silky Terriers)
2003 Ford F350 Crew Cab "King Ranch" Power Stroke 6.0
2007 Mobile Suites 36SB3 Extra Class Amateur Radio Operator
gatorcq
And by the way, putting the ZIP code in the receiver does NOT give you the local channels. You MUST call tech support and state you want to Change your service address and that your mailing address remains the same.
You are then required to give them a good address whether or not you live there is of no concern
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
