Feb-19-2017 01:26 PM
Feb-20-2017 04:16 AM
Hobo2 wrote:
...I will bring 3 spare batteries in series....
Hobo2 wrote:
...Have not tried the solar system as of yet. We are full-time now. Have not done any dry camping as of yet....
Feb-20-2017 02:52 AM
dons2346 wrote:Lwiddis wrote:
" dry camping .... residential refrigerator" equate only with many dollars spent.
Well, this is a worthless post. It is obvious that you have no idea about the requirements needed of a residential refer. We manage a refer with 500 amp hours of battery for almost 20 hours without needing a generator
Feb-19-2017 07:01 PM
Feb-19-2017 04:30 PM
Feb-19-2017 03:59 PM
Feb-19-2017 03:32 PM
Feb-19-2017 03:29 PM
Feb-19-2017 03:13 PM
Feb-19-2017 03:11 PM
kohldad wrote:
The residential fridge is going to be the biggest problem. If you don't open up the doors and have some ice jugs you can put in there, it would help the load. An alternative would be a few pounds of dry ice wrapped in a towel.
Doing a quick internet search, it seams for 11 hours you will need 200A/hrs which includes the inverter draw, so about 182 A/hr for the 10 hours you specify. This will required 4 batteries to provide the power.
The maxair set on it's lowest setting will draw about 3A/hr for the 10 hours means 30A/hrs. That is a little over 1/2 of one battery. The other standard parasitic draws will require the rest of the battery. This also means very little light usage.
Therefor, you may squeeze by with 5 batteries unless you help the fridge with ice jugs (which you can refreeze each day while on the generator). The ice jugs would probably give you enough to spare for the lights.
Edit: Here is the article for reference on someone who put a residential fridge in their RV: Article
Feb-19-2017 03:10 PM
Feb-19-2017 02:55 PM
Feb-19-2017 02:46 PM
Feb-19-2017 02:33 PM
Feb-19-2017 02:22 PM
Feb-19-2017 02:13 PM
