โJul-18-2013 11:27 PM
โJul-27-2013 01:33 PM
โJul-27-2013 11:45 AM
โJul-27-2013 09:03 AM
RoyB wrote:
It has been my experience to beef-up the trailer first to run all the things you want to run from the batteries. Then add the 2KW generator to that to be able to connect to the shore power cable to allow your on-board smart mode converter/charger to recharge your batteries in as little as three hours time which is the only way to be able to recharge a deep cycle battery setup.
Using the generator is the only "sure" way to re-charge your batteries as it will work in all weather situations.
Once you get successful running all the things you want to have with you then start adding some solar panels just for the purpose of re-charging your large battery bank during the daytime when the sun is out...
This is where I am now in my long term beef-up for camping off the power grid. As you start increasing the solar panels then you can start cutting back on the use of the generator. Eventually you can go several days without running the generator at all and still be able to run all the things you want to run.
But what I have found out you will need to always have the generator around for that last PLAN B effort for keeping the batteries re-charged. You may go weeks without much enough sun light to run the solar panels...
Got to have the PLAN Bs to be successful camping off the power grid...
Just some of my thoughts on how we have progressed along the camping off the power grid experiences...
Also if you are lucky enough to be able to have your RV Trailer parked at your house when not on the road then all of your Battery beef-up planning is like having a large UPS system for your house when bad weather storms knocks out your power for weeks on end. I have used my trailer setup to support the house on four occasions now, One event was for over a week without power here in the county when one of hurricane Irene came through a couple of years ago... this payed us back big time and also helped out in the community here helping folks keep their fridges powered up a couple hours a day. My neighbor RV guy and I put the 2KW Honda generator in a kids wagon and visited all the local elderly folks houses and kept their fridges going. All it cost was a cup of coffee and some conversations hehe...
โJul-26-2013 06:12 AM
โJul-23-2013 09:54 PM
โJul-23-2013 06:41 AM
โJul-19-2013 08:24 PM
โJul-19-2013 06:43 PM
โJul-19-2013 09:02 AM
โJul-19-2013 07:11 AM
โJul-19-2013 06:48 AM
Caseyjones955 wrote:Depends on what you're running with it. It's overkill for a TV but not a Mw and even occasional short a/c use.
3000 watt power inverter. Is this overkill? does it serve any practical purpose?
โJul-19-2013 06:06 AM
โJul-19-2013 05:53 AM
โJul-19-2013 05:29 AM
โJul-19-2013 04:19 AM
