Feb-21-2019 09:28 AM
Feb-21-2019 05:32 PM
Feb-21-2019 04:51 PM
bobsallyh wrote:
This is done thousands of times over in the Yuma area. Drain water heater, open black and gray tanks, pour wind shied washer fluid down kitchen sink, vanity sink, and pottie (some use vegetable oil). Then cover those drains with Saran Wrap and stretch Saran Wrap across pottie below the seat. Top off batteries and disconnect. Turn propane off. Place plastic buckets full of water in bedroom, bath, kitchen, and living area. DO NOT use milk jugs. Take anything with elastic in it with you. Put silver bubble paper in the vent squares inside. Silver bubble paper all windows (between glass and blind). Some put plastic sheets over chairs etc. You can build small boxes to cover roof vents up on the roof. Also, you can build a larger box to cover AC unit. Be sure to put a patio block on each box cover. Put silver bubble paper on inside of refer vent door. Let refer doors open. You can take plastic spouting and cover your roll-up awning. cover tires and put weight against the covers. You will be surprised how good it will be inside when returning.
If I can be of more help just PM me. We do several for our friends after they leave.
Feb-21-2019 03:51 PM
Feb-21-2019 01:06 PM
Feb-21-2019 12:53 PM
Feb-21-2019 09:43 AM
