1980's decor
Planedenn
I don't know where else to post this since it's a question but if it's moved please tell me where you move it to.
We have a 1983 C class with a very 1983 brown and flower decor my wife has developed a hatred for. So here's the question. What type of paint would be best to cover the flowery wallpaper? We thought exterior latex paint would be best but before starting I'd like to here some options
7 REPLIES 7
Sturgeon-Phish
Scrub the walls especially around the stove and shower and vanity area to remove grease, soap film and hair spray residue. KilZ is a good idea and use a good primer, not just regular paint, tinting the primer helps too. Then go with a very washable paint, avoid flats, and paint away. Anyting will look better than the brown orange and yellow flowers from the '80's.
Jim
2003 GMC 3500 crew dually. Transfer Flow 50g aux tank; ISSPRO gauges, PPE boost valve, air box mods, stock exhaust w/o muffler, Line-X, Pace Edwards bed locker power tonneau. B&W Companion. Pulls a '05 Wildcat 31QBH 5th wheel
Ron3rd
robatthelake wrote:
Start with Kill Z ! Then paint it with whatever You want!
Good suggestion, but make sure none of the wallpaper is coming off. Painting over wallpaper used to be common when wallpaper was in vogue.
Equilizer Hitch
Honda EU2000
spoon059
NCWriter wrote:
Probably 2015 RVs will come out with the latest thing - brown and flower decor - right after you finish the job.
Ha ha ha... I was just thinking the same thing. For the love of everything holy, I pray that doesn't happen. I grew up in 70's and 80's campers. They were HORRIBLE! Thick scratchy fabrics in dark greens and browns... ugh...
2015 Ram CTD
2015 Jayco 29QBS
Planedenn
Pretty much what I have in mind too ๐Ÿ™‚
NCWriter
robatthelake
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
westend
Conventional wall paper is usually primed and then painted. Vinyl coverings are usually the same, prime and paint. The finish paint can be any type but a good quality interior latex would be my suggestion. The newer ceramic additive paints are quite durable and may fit the application well.
'03 F-250 4x4 CC
