3M 5200 fast cure
SHRED
Anyone know what the shelf life is after opening the small tube?
The bigger gun tube needs to be used fairly soon in my experience.
Great stuff.
2021 27' Lazy Daze mid bath
5 REPLIES 5
otrfun
3M recommends a 3 oz tube of 3M 4000UV be used within 24 hours of opening. I've found it stays somewhat pliable for almost a week as long as you seal it tightly. 5200FC cures in similar time as 4000. Standard 5200 takes much longer. FWIW (in terms of RV use), 4000 is much more UV resistant than 5200.
navigator2346
Before you put the cap back on, smear a little grease of some kind on the threads to make removing the cap easier
Seon
As JSP mentioned, store it in a freezer. I have all my sealant stored in my "bait" freeze, some as old as 5 yrs. Never a problem unscrewing the cap. Might have to prick the tip with a nail but then it'll flow after squeezing the tube.
jspringator
It is longer if you store it in the freezer.
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
dhull
I have a 4 year old tube I used a little from that is still pliable in the tube. Can't get cap off tho!
