Can't seem to find the diagram I had seen here previously. I'm changing from 2-12 volt parallel to 2- 6 volt series batteries. I've found diagrams to show connecting the two batteries together + to -, but am not certain on inputs and outputs for generator, solar panels and battery monitor. All negatives attach to battery one and all positives to battery two, correct? Thanks.
Etrailer schematic You have the theory correct all inputs and outputs will connect to the outboard terminals of the two batteries. Nothing is connected to the inner, series cable link.
