yes its possible, you will need a 30amp double pole double throw toggle switch
for manual switching, between RV use and outlet use for the house
manual switch not automatic,
can't be automatic, because you will use generator for RV or house
so there is NO automatic setup that would not always go to the default when generator is running
how much do you know about 120v power, and DPDT switches
you need to open the junction box where the Onan wiring connects to the RV
you need to see 5 wiring connections, (2) sets of black wires, (2)sets of white wires, and one set of green wires
if you see this, you have a 30a circuit for the RV, a second 20a circuit for the second A/C
so you can interrupt (1) circuit and run it thru the switch
connecting power in, RV and outlet all to the switch
you will need a box for the outlet
and probably one for the big DPDT switch
your RV outlets should be 15a duplex outlets on a 20a breaker
the easiest thing would be to replace the outside patio outlet with a 20a duplex outlet,
and use a 12ga 20a extension cord to feed the temporary power to the house
I can explain it to you.
1997 F53 Bounder 36s
