Adding 12 volt outlets
scrubjaysnest
This is pretty straight forward, usual warnings apply. Check clearances, insulate wire areas that may rub, use proper crimp technique, and fuse/breaker correctly.
Pulling the wire.
Expanding for jumpers.
Heat shrink.
Connecting up. Make sure all slip ons are tight, loose connection is a fire hazard.
Done.
Axis 24.1 class A 500watts solar TS-45CC Trimetric
Very noisy generator :M
2016 Wrangler JK dinghy
“They who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” Benjamin Franklin
7 REPLIES 7
All_I_could_aff
I'm in the process of adding a few more myself this month. I like your sockets better than the ones I'm about to use. Where did u get them and how much?
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
DaHose
Turned out nice. Well done.
Jose
tenbear
The power goes to the socket on our right and the other wires are jumpers to the other socket.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
pconroy328
why did you double up wires on the one side? for higher amp draws?
Tom_M1
scrubjaysnest wrote:
insult wire areas that may rub
Shame them into not rubbing! 🙂
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
2oldman
If you insult them they are too embarrased to rub.
tenbear
Nice job!
