Adding a the fence post sewer hose storage, A question.
gaymeadowsman
Good morning everyone, I'm about to add the fence post storage tube for my sewer hose and connectors under our trailer. For those who have done this and had to mount where it was in contact with the gas line, how did you work around it?
1.) Notch out the fence post to go over the gas line.
2.) Add a spacer to the other side so tube remains level.
3.) Just not worry about it and and put some kind of wrap over the gas line and hang the the tube.
Thanks for you help.
John ๐Ÿ˜›
Ted :R
in search of the next one
2010 Chevy Silverado Ext Cab LT
2015 Chevrolet Impala LT
37 REPLIES 37
downtheroad
Hornnumb2 wrote:
Just ordered my fence post yesterday, any more pictures of how they are mounted. Thanks Michael
Here is mine...I used 10 industrial strength zip ties from Home Depot.
Each has a strength rating of 250 lbs. Mounted the post to a frame cross member near our dump valve.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
PRodacy
I put spacers on mine. Easy to do and I didn't want to take a chance on damaging the gas line.
2012 GMC 3500 dually 4x4
2006 OKanagan 90W
2003 Jeep Rubicon, modified for off road performance
time2roll
Gas pipe is steel, copper or some flex line?
Steel just slap it on. Anything else I would mount for some clearance.
Walaby
So is this a better option than storing it in the rear bumper of the TT? Or is this because you don't have the rear bumper storage.
Just curious is all.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Hornnumb2
Marine_By_Choic
I made sure mine was a little "downhill" opposite the opening and drilled a few holes in the bottom at the low end to let any lingering water escape. Just a thought!
jmtandem
Add a spacer
Add a spacer on both sides so the box does not touch the gas line.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
goducks10
I added spacers.
