Atwood Air Conditioner..... Your thoughts
jasonthewelder
My dometic brisk air A/C quit cooling. I'm thinking about switching it out with the Atwood Air Command 15,000btu unit. Does anyone have any experience with the atwood air conditioner? Thanks
3 REPLIES 3
C_Schomer
All of our RVs have had Atwood and they are so-so. Noisy and inefficient like any other poorly designed AC. High evap. DT, good for the latent load but not for the sensible load or efficiency. I don't know if any RV AC is any better. I wish the gov't would make all the AC mfgrs use the seer rating. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
Bull_Rider
We replaced a Dometic 13.5 ducted A/C with the Atwood 15.0 Air Command Cormorant model. One of the best upgrades we've done. Much quieter, much better cooling and it can be used for heat too.
We've ran the new A/C several times with our Honda 2k generator. I've posted some of the test info. here on this forum, you'll have to do a search.
Nice unit, very pleased.
If you receive help from other members, don't forget to update your topic with the results.
houstonstroker
I added a second air conditioner to my 30 amp 5th wheel, an Atwood Air Command, 13500 non ducted model. It supposedly has the equivalency rating of 16000. Anyway I needed a unit that would run from one 2000 watt generator. Started and ran just fine and also runs at my storage unit where 15 amps is available. It has a flip down display and a remote. Just bought it but it works just fine. Blows cold air.
2016 Dynamax Force HD Super C
