Building a small trailer from scratch
profdant139
Someday, I will have to do this. In the meantime, it's fun to watch someone else do it:
DIY Trailer
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
6 REPLIES 6
Dutch_12078
GordonThree wrote:
What is the structure on top of the trailer called, the part that is holding up the walls?
Wall framing...
Dutch
2001 GBM Landau 34' Class A
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
Optimistic_Para
If you're into this sort of thing, the Teardrops and Tiny Travel Trailers forum is full of threads devoted to building your own.
Dutch_12078
The aluminum siding is attached with VHB tape, so there's probably some give that will help mitigate the flexing. The frame construction isn't much different than the commercial steel/aluminum framed RV's.
Dutch
profdant139
The steel frame will be ok -- but the flexing could do some interesting things to the exterior skin . . . .
About our trailer
GordonThree
Quite a project. I haven't seen any hand made camping trailers that looked that nice on the outside. He really did well with the skin. The DIY trailers and truck campers around here are just plywood nailed together and painted.
I wonder how the ridged steel frame will hold up not being able to flex as the trailer trundles down the road?
