โMar-20-2018 11:13 AM
โMar-21-2018 12:10 PM
โMar-21-2018 11:37 AM
profdant139 wrote:
Probably there is no way to know for sure until I try it out in the real world.
โMar-21-2018 10:59 AM
profdant139 wrote:
Well, I just thought of a show-stopper. Yes, I think I can get this to work, based on what I have read above. And by the way, I have been doing a crude imitation of this project by running a tube from my sink faucet through the hatch to the outdoor shower and out to the fill port for the fresh water tank -- I just turn on the hot water and let it flow for a while. (This has worked (obviously while we are parked!) in temps down to ten degrees above zero Fahrenheit.)
But here is the deal-killer: I realized that if I were to try to use my proposed "automatic" system for boondocking, the water pump would be cycling on and off all night long. Even though I have installed an accumulator and have isolated the pump as much as possible, it would still wake us up from time to time -- the trailer is very quiet at night.
So I don't think I am going to pursue this particular option. My fallback is to check out the various electric tank heater options and see if I can power them with my batteries without draining the batteries too much. I have to figure out the minimum wattage that will still do the job and then calculate my battery capacity and my ability to recharge.
If I install the smallest possible heater under the low point of the fresh water tank (which is the Achilles heel of the whole system) and then install very thick and tight insulation, that might be sufficient.
โMar-21-2018 10:49 AM
โMar-21-2018 10:08 AM
โMar-21-2018 07:28 AM
โMar-21-2018 04:45 AM
MrWizard wrote:Lantley wrote:
Since hot water can freeze faster than cold I think you maybe going down the wrong road.
While the water in the pipes may freeze as long as the tank remains in motion the chances of it freezing are reduced.
HOt water looses heat faster than cold water , because it has heat to loose
this is one of those 'phrases' that is always miss-stated and miss-interperted
it will NOT freeze UP, before an equal size tank of cold water does
it has too loose all that heat before it can began to get cold
he might be talking about an enclosed sealed water heating tube system
not feeding hot water into the fresh water tank ?
convection would keep it circulating, WH would not run constantly
or maybe use a small aquarium/fountain pump
certainly it can be done
my first class A, had a WH with pilot flame, i left it on pilot all the time, except for LP refills, it never blew out
โMar-20-2018 10:44 PM
โMar-20-2018 08:52 PM
โMar-20-2018 07:52 PM
coolmom42 wrote:The link is my system. OP is still in design phase questioning if the water heater will stay lit while in transit. OP wants to use the water heater to keep the fresh water tank from freezing.time2roll wrote:profdant139 wrote:The system was recently upgraded to use the furnace signal to trigger the pump to come on. The more the furnace runs the more the pump runs. No chance to hear the pump while the furnace is running.
Someone asked for a link to an earlier recirculation project:
Hot water recirculator to prevent freezing of lines
So OP will be using both the water heater and furnace while on the road? Sounds a little tricky, but it might work.
It would be a good idea to put a remote temp sensor both inside the RV and water tank area, so temp can be monitored. If the furnace, pump, or water heater fail, things could freeze up.
โMar-20-2018 07:17 PM
โMar-20-2018 07:08 PM
Lantley wrote:
I like the idea of the circulator pump. But what stop water from freezing within the individual fixtures? Like the toilet valve or kitchen faucet.
Sounds like others have taken this approach so I assume it can be done.
I have never tried to travel with my water heater on in gas mode.
โMar-20-2018 06:34 PM
โMar-20-2018 06:25 PM
riven1950 wrote:
Hot water does not freeze faster than cold water. It will lose heat at a faster than coldwater. At some point hot water becomes cold water and then the freeze rate is the same, if that makes sense. Put a bucket of 100 degree water and a bucket of 40 degree water outside in freezing weather and see which freezes first.
โMar-20-2018 06:16 PM
pianotuna wrote:
Hi,
If the belly is enclosed and heated by the furnace then just run it instead?
I use a twin window fan to cause warm cabin air to circulate through the duct work. It draws a whopping 27 watts.
