INSTALLATION
The jacks come with self-threading mounting screws (and a socket and drill adapter). The shank diameter of the screws is a shade over 11/32" so I will drill the mounting holes in that size.
I didn't do anything as fancy as finding the exact centre of the trailer; I wanted the jacks a little forward of the rear wheels so I centred the jacks on the midpoint between the wheels and the steps.
With the curb side jack in place, I marked the drilling locations with a hammer and transfer punch.
Drilling the holes was an adventure. I learned a lot about drilling into steel; some from others, some from experience:
- Drilling slow is the way to go, with just enough RPM to keep the bit turning
- High speed drilling:
- results in a painful shower of red-hot and needle-sharp twists of metal
- tends to break drill bits
- allows the steel to heat and cool, hardening it and dulling drill bits
- Dull drill bits are dangerous and time-wasting
- Sharp drill bits will eat through steel quickly even at low RPMs
- I have a lot to learn about sharpening drill bits
- Drilling upwards into a trailer frame while lying on your side is uncomfortable
- WD-40 makes a passable cutting fluid for drilling a trailer frame
- I still have a lot to learn about drilling into steel
I spread the drilling over the span of several days. Eventually the job was complete and I secured the jacks to the frame with the screws and thread lock.
A quick driveway test with all six stabilizers down reveals that most of the wiggle is gone. I think we can remove the remainder by chocking the wheels on both sides and tightening the centre jacks a little more.
2008 Starcraft ST 2700BH behind 2013 Ford F-150 SuperCrew EcoBoost FX4.
Linked by
ProPride 3P 1400.
restcure.ca
