Completed First Major Mod
BassinDmax
Completed the first upgrade to our trailer. First step in gettin off the beatin path and not having to worry about plugin in.
Installed a 48" box to house the new Trojans
The four new Trojans went in
Installed a Magnum MS2012 in the pass through
Mounted the Trimetric & Remote in the coach
Tim & Mary
11 REPLIES 11
tenbear
Really nice job. You might consider putting a lock on the box, I keep reading about batteries being stolen.
2010 Subaru Impreza Sedan
goducks10
Exc job. Nice and clean.
BassinDmax
profdant139 wrote:
Wow! Where did you get that terrific battery box? Thanks in advance.
It's a 48" pick-up bed side rail box made by Tradesman. I modified it to work on the tongue.
Tim & Mary
BassinDmax
pianotuna wrote:
Hi,
Very nice! Is that one of the new hybrid inverters?
Thank you,
No, not a hybrid, MS2012
Tim & Mary
profdant139
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
pianotuna
Nomad II
Nomad II
Hi,
Regards, Don
BassinDmax
BurbMan wrote:
Very clean, nice work! 4 batteries should hold you for a while, wish I had room to do that. What about venting that battery box?
Thank you, for venting I drilled 2" holes and installed louvered vent covers to protect. Drilled a couple small drain holes in the bottom in case of water intrusion.
Tim & Mary
gbopp
Nice, clean job. It looks professional.
Thanks for sharing.
BurbMan
sh4717
Looks great!
Scott
2019 Northwood Nash 24M
2018 Ram Ecodiesel
64thunderbolt
nice install
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
