โMar-23-2013 04:55 PM
โJun-03-2015 08:12 PM
โJul-21-2014 03:51 PM
โJul-05-2014 07:24 PM
โApr-25-2014 06:28 PM
โApr-05-2014 03:55 PM
โApr-05-2014 01:09 PM
โApr-05-2014 05:17 AM
smkettner wrote:
Although I think I see the red/white wire in my pic. Maybe I don't recall correctly.
I could swing by storage tomorrow and look at it.
It has been more than a year since I poked at it ๐
โApr-04-2014 07:16 PM
โApr-04-2014 07:12 PM
โApr-04-2014 06:31 PM
smkettner wrote:
This short description may help with the wiring to the thermostat:
Seemed tricky but it is easy in the end. If you think you will get crossed up then put some tape on your wires to mark them before you cut.
The way mine worked there are two 12+ wires coming from the RV ceiling. These are black as shown in the thread pics. 6th pic I think. These two 12+ wires need to be reconnected to each other and with the 12+ to the box and the 12+ to the thermostat. So 4 wires connected in a bundle for the 12+. The box harness wire is red and is labeled. I connected the red wire in the thermostat bundle to be consistent. Then when you get to the actual thermostat you connect the red wire to the 12+ terminal. Done with 12+.
Similar with 12-. Four wires to connect in the ceiling. The RV 12- are white, box harness is black, I used the black in the thermostat bundle. Then at the thermostat the black is connected to the 12- terminal. Done with 12-.
Last is the signal wire. Just two connect in the ceiling. Box harness is orange so I used the orange wire in the bundle. At the thermostat connect the orange wire to the signal terminal. Done with signal wire.
Color to the thermostat does not particularly matter as long as the 12+, 12-, & signal wire connect same in the ceiling as the thermostat. If you think you might get red/orange mixed up then use green or blue for the signal wire. The unused wires just get folded back out of the way. The replacement is actually a simpler connection than the existing.
Then connect the 120v power, freeze sensor and the heater control wires. Done.
โMar-18-2014 09:35 PM
oceansailor wrote:
I purchased the same model Dometic T-stat and box for a new A/C unit. Wanted to replace the old analog Duo-term t-stat. However, I do not have wiring to the furnace up by the A/C controller unit. In fact, I wonder how my furnace was controlled...
JP
โMar-18-2014 09:34 PM
Seattle Lion wrote:
Our TT is fairly new. Bought it last June. It has a digital thermostat. We have had a big problem with it and with our dealer understanding the problem.
The thermostat seems to "think" it is 10 degrees cooler than it actually is. For example, last summer it was in the 90's outside. We set the thermostat to 70. The AC ran for a while and then the thermostat shut it off. The actual temperature as measured by a digital thermometer was 82 degrees in the TT. I lowered the thermostat to the lowest temp...68 I think...and the AC ran again and once more shut off at 80 deg. The heat mode was similar.
The dealer said the thermostat was ok because the thermometer built in to the thermostat agreed with the setting when heat and ac turned off. I tried to explain that the thermometer in the thermostat was wrong. So frustrating! Obviously, I am not a fan of this thermostat. I would love to replace it.
โMar-18-2014 09:19 PM
โFeb-03-2014 09:04 AM
โFeb-03-2014 08:51 AM
