freezer door seal
thoms
Does anyone know where can I get a replacement door seal for a norcold N611 freezer door? checked all parts sites on internet but no seals???
seems this should be a common replacement DIY?
Thanks to all
3 REPLIES 3
cavie
Old-Biscuit wrote:
Norcold Fridge Door Seals are NOT replacement items.
They are incorporated within the door
So Norcold wants to sell you a complete new door!
Folks have cut the old seals off and used glue on / self adhesvie generic seals
Sometimes you can 'reset' the seals
Place a cotton ball in each corner under the seal
Heat the seal using a hair dryer, warm air heat gun etc until the whole seal is warmed up
THen close door and let seal reform to fridge frame
After it cools remove the cotton balls and check if sealing has improved
I like that trick!
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
RLS7201
If necessary, the whole door is available.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Old-Biscuit
