fridge exhaust fans added
popeyemth
screened the access door vents to keep out bugs and was concerned that may hinder the already marginal air flow.
decided to cure that by adding 2 fans to the top
fastened them in with #8 X 1 1/2 inch screws and nuts (menards). added screen wire up here on the roof too,held down with 5/32 fender washers (menards)
instead of 2 at the bottom I used a single larger fan that was on hand.
this fan is mounted with a combination of ty-wrap and silicon adhesive. Check as you go because a little twist in the plastic frame binds the blades.
the fans are activated with a thermostatic switch jammed between the fins of the heat exchanger at the top of the fridge exhaust.
just because i like to know whats going on I mounted an LED (Radio Shack, $1.99) inside wired in parallel so it lights up when the fans come on.
the three fans and switch and the light are all connected with 22 gauge wire and protected with a 2 amp fuse.
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
13 REPLIES 13
rrev
Jbarca, thanks for the info. Looks like i have another mod to do. Haha. It would probably be very beneficial for us being it seems sometimes my fridge door is open as much as it is closed.
2008 Chevrolet Silverado 2500HD CCSB
2016 Starcraft Autumn Ridge 329BHU
2007 Starcraft Homestead 282DBS (Retired)
toddb
Make sure you baffle around the condenser, if you have large voids around it closing them off helps greatly. One large fan is sufficient if the air is forced over the condenser.
JBarca
Nomad II
Nomad II
rrev wrote:
Now for the stupid question..... Does adding the fans make the fridge really work better? I have no idea so please don't take it the wrong way.
Oh yes. This mod the OP did a great job with. I did mine up top in the roof vent. I only used one fan and the difference in performance was significant.
My fridge now holds 32 - 33 no issues. And it comes down faster too. Before it would flounder around up and down from 33 to 36 and and back down and never open the door. Now stable.
The sad part of this, Dometic knows putting the fans in helps. On there larger units they install them at the factory. So why not add this to every unit? Well $$. The few extra dollars creates large savings when your pumping out thousands of unit.
Here see a Dometic factory install
Here is mine
Folded down the screen and Dicor'ed back in
This is a very worthwhile upgrade.
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
rrev
hl_remington
Good write up, thank for the info.
Gjac
93Cobra2771 wrote:
31.21 cfm is what it looks like to me. 3121 cfm is comparable to cooling fans on cars at full speed...
Your eyes are better than mine. I was guessing 312.1 only because it looks bigger than the average computer fan.
93Cobra2771
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
Gjac
Nice post. On the fan at the bottom it looks like 3121 CFM I can't read a decimal is that 312 of 3,121 CFM? What is the CFM of the other 2 fans on top?
ianmac23
How did you get the wires through the wall?
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
NC_Hauler
Most excellent write up with illustrations....A very informative post:)
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Nomadac
Thanks for all of the info and parts used.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
austinjenna
You did a great job with your installation. Your write up was detailed and should help out others.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
gbopp
Nice write up. Great job!
