Hand Hold to Climb into upper bunk
TenOC
I have seen a picture some place of a strap "hand hold" on the wall of the upper bunk bed  to help the child climb in the the bed. Has any one added some type of hand hold?  Any photo or suggestion would be helpful.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
3 REPLIES 3
ewarnerusa
As long as you're at Home Depot.  Here is a handhold like I mentioned using.
https://www.homedepot.com/p/Swing-N-Slide-Playsets-Multi-Colored-Plastic-Climbing-Rocks-NE-4543S/205...
Aspen Trail 2710BH | 470 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
Cybergrunt
On a previous TT with bunks, I basically did the same as @ewarnerusa . What I used were handles meant for use on an outdoor plays set. Fast, easy, cheap and held up great to use/abuse.
https://www.homedepot.com/p/Swing-N-Slide-Playsets-Green-Safety-Handles-2-Pack-WS-4410/204844067
2021 Forest River Wildwood Heritage Glen 24RLHL: 810-825# TW, ~7500# GVW
2020 F-250 XLT Super Duty SRW: 7.3 V8 gasser, 3.55, 10spd
ewarnerusa
I added a nylon rock climbing wall handhold for this purpose.  Another down lower for a foot hold.
