HVAC Soft Starters -> Any Good?
ng2951
Bear with me, because I am having trouble posting here.
I have been reading about these devices called soft starters. They are microprocessor controlled devices that ramp the current to the compressor at startup during about the first second or two. It makes sure the compressor has enough current to function but not the high peak Locked Rotor Amps the compressor demands.
The big advantage is that when running a HVAC on one of these units it controls the LRA reduces it by about 70 percent. It learns how the compressor demands its startup current during successive 5 to 10 startups on shore power. Some claim, though I have not verified, that a 13.5KBTU HVAC can easily be started and run on a soft starter with a single 2000 watt inverter in eco mode.
There are several manufacturers of these units:
Foard County News & Sassy Schoolmarm
with Chloe, Belle, & Danke
2017 GD Imagine 2800BH
2017 53 days camping
'07 GMC Sierra 2500HD Classic 4x4 LBZ Duramax Diesel
Honda 2000sThe Bayou Bounty Hunters Cowboy Club
The Single Action Shooting Society
4 REPLIES 4
TexasChaps
I have the Hyper engineering one on my rv, works like a champ..
it does what it says and my generator on ECO setting will start the a/c with ease.
ng2951
As I researched these units, it sure seemed like Micro-Aire was selling a bunch to either manufacturers or equipment vendors.
Are those kits available without voiding warranties?
Chris_Bryant
The Dometic Smart Start II is basically a rebranded Micro-Air unit, as I understand it. They do make a huge difference in starting- no comparison to the capacitor start kits.
-- Chris Bryant
ng2951
Here is part II
Hyper Engineering
Micro-Air's Easy Start
Emerson also makes one but I have not been able to successfully post its URL.
Some forums claim that these soft starters are part of higher end HVACs. One says Dometic uses these on some of their HVACs. Others that have used these report the units cut light dimming, startup noise, enhanced longevity.
One thing seems pretty clear that adding one of these to a HVAC in the warranty period would likely void the HVAC warranty
Comments?
