I've been slowly working toward the solution to be able to run our 2006 VH completely (water, showers, etc) in the winter. Here are some of the items that I have completed and items on the task list:
-- completed the mod to run the Espar heater without the engine running.
-- added hose to hookup the Motoraide feature on the water heater. This will allow us to have the water heated as we drive and also when we run the Espar Mod without the engine running.
-- wired the Espar heater to run off the "Electric Heat/Heat Pump" option on the motorhomes thermostat. This will allow the furnace to be an "online" backup to the Espar pre-heater and also allow us to set the thermostat and that will cycle the Espar on and off as needed.
Next UP:
-- ordered Aqua-hot Cozy III heat exchangers (about .5 amps). I plan to tie the heat exchangers into the hot water heater instead of using the engine heat (motoraide hoses). This way we can get heat by using propane, electric, driving (motoraide) or Espar Mod to heat the water. The only concern is the water temperature from the water heater being not hot enough, but I measured the temp at 135 degrees from the bathroom faucet with the electric switch on. These heat exchangers will also be switch from the heat pump switch on the thermostat.
-- ordered RedyHeat to keep the pipes from freezing. Will hook this unit up to the water lines in the "water compartment". This will circulate the hot water back thru the cold water lines to the hot water heater. This is temperature controlled (based on water temp) and uses very little amps.
-- already have a Honda 2000eu generator that we'll use when needed. The Honda barely sips any gas and is quieter then the onboard LP generator.
-- ordered thermostat controlled electrical 12v switch. This will allow the control of the water heater temperature based on the thermostat. The electronic switch will be wired to turn on the Propane, Electric, and/or Espar Pre-heat. I like the idea of knowing the water heater temp prior to jumping into the shower or turning on the water heater just because we don't know the temp. With the motoraide connection, we did not need the water heater on most of the time - but a few times it was a cold shower when we had used up the hot water. This will take the guessing out of it.
Meyer Meyer - 2006 Winnebago View / 2008 22 C-Dory
Recent travel map: https://spotwalla.com/tripViewer.php?id=a07a538ddea1dca24
