Kind of adhesive?
chast
Newly applied vinyl pin stripping will not adhere in a few spots. Cleaned the area well with acetone, but the stripe still refuses to stick. What type of adhesive should I use to make it adhere without damaging the stripe? I tried a contact cement that is solvent based and it wrinkled the stripe. Any suggestions? Thanks, as usual.
chartrue2@aol.com
2 REPLIES 2
profdant139
Gosh, I'm lost once we get beyond duct tape. ๐Ÿ˜‰
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
MrWizard
Moderator
Moderator
I would try 3M auto trim spray adhesive
I can explain it to you.
1997 F53 Bounder 36s
