Mounting 90 deg. or 45 deg. entry door holders
pmona
For those of you using a 90 deg. or 45 deg. entry door holder, how are you doing it? I ask because those holders will typically land somewhere on the door where there is no solid wood on the interior....typically several inches in from the edge where the door is a thin skin over a foam core.
1 REPLY 1
4x4van
BOTH pieces must be located and oriented where there is good support; not always easy, but pretty much required. If the location of one results in a bad location for the other, then the first needs to be relocated or modified.
If relocation is not possible, then how about a larger aluminum plate (1/8" thick, painted) attached (using screws or pop rivets) to either the wall or the door to give additional support where is needed?
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
