โJul-23-2019 01:11 PM
โJul-26-2019 08:46 AM
DrewE wrote:
Why would they care to keep the mount from contacting the fiberglass? Window frames contact the fiberglass. Awning support arm brackets contact the fiberglass. Door hold-open gizmos are mounted to the fiberglass. I can't think of any reason why a TV mount would be any different. I still suspect what you're seeing is just a sealant or gasket of some sort to keep water out.
โJul-25-2019 10:02 PM
โJul-25-2019 08:05 PM
Lantley wrote:
Another option I have seen is to just put TV on a folding table.
I have also seen TV suspended from and awning.
As Barney mentioned above you can through bolt it easy enough but I have never seen an RV with a TV bracket permanently mounted to the side.
โJul-24-2019 09:06 AM
โJul-24-2019 06:52 AM
โJul-23-2019 09:41 PM
Lantley wrote:Str8ball1 wrote:Lantley wrote:
Try This. No Drilling Required
***Link Removed***
Yeah I have seen those. Expensive and dont trust a suction cup much.
Thanks though.
I agree they are expensive but they work, You can trust them to hold.
I don't have one but I have seen them personally. They are a worthwhile option if you can stomach the price.
Once you consider your alternatives, there is no other option quite as simple and to the point as the suction cup. No drilling, no penetrations.
No marks, no alterations
Otherwise you need to construct some sort of cabinet or permanently mount some sort of bracket to your exterior.
The suction cup eliminates the need to do anything permanent.
โJul-23-2019 07:30 PM
***Link Removed***
Thanks though.
โJul-23-2019 06:48 PM
โJul-23-2019 05:43 PM
riven1950 wrote:
Don't have one or any mounting suggestions but thought I would mention a setup I saw in the Keys last winter. This may be common or not. My neighbor had his tv mount attached inside of the storage compartment so that when retracted it was inside the compartment, not attached to the outside wall at all. I believe the tv stayed attached. Downside would be eating up your storage area and of course you would need a storage area where you want the tv. Just a thought. I would not do it because our TT has limited storage, plus we don't need / want an outside tv, but most 5th's and toyhaulers have more storage compartments.
โJul-23-2019 05:40 PM
***Link Removed***
โJul-23-2019 04:20 PM
โJul-23-2019 03:57 PM
โJul-23-2019 01:59 PM
