I'm at work, and if you are typing, you are busy so.....
I am about to retire and travel America. It has been my dream since I joined the Army, and its about to be a reality. Bonus the wife is on board and totally motivated.
However, she is a pro photographer and has an insane amount of equipment. We will also have our 5 boys along with us for the Summer part of the adventure.
Needless to say, space is an issue. So I went on a Space Quest.
I found space everywhere.
Under our sink, there is only one drawer to access the area, which made the furthest area very difficult to use as storage. Solution, I made another drawer.
BEFORE
AFTER
The Entertainment area has an LCD TV, but the MFR didnt change the empty space behind it. ALSO, the top cabinet was inaccessible while the slides were in, thus blocking the adult beverages therein.
BEFORE, I made a pilot hole where i thought the back panel for the TV was approx. I was within 1/2 an inch accurate.
All this space, and it allows access to the top cabinet.
The door has a mirror so the ladies can see how cute they are on the way out the door.
Under the stairs I found this space, and i added velcro to the step so it can be opened and closed. The top step could also be opened, but the space was small enough there it was not worth the time.
The last of the construction type mods.. Our camper has a heated storage bay. This vent connects the storage bay to the main camper for air flow. I actually had the vent in the bay closed off as we have not winter camped (yet). However this space was huge and hard to get to from the bay.
BEFORE
AFTER
Future mods....
*12v regulator for LED lighting. The lighting in the camper gets battery voltage, and if they are charging can be ~15v. EXPENSIVE camper LED bulbs are usually OK with this. However, I have cheaper LED Bulbs that do not like 13+ volts. SO a $10 voltage regulator accepts any incoming voltage, and locks it at whichever voltage you need. I will lock it at 12v, to stop faster burn out of the LEDs.
I also use one for the computer fan I have set up to suck battery vent gas out of the sealed battery box. Computer fans also do not like voltages above 12v.
*I will be pulling out the fridge and adding tubing fans, and an auto dispersal HALON fire ext. Just in case.
*I will be adding 2 more 100w Solar panels to cap the array at 45 amps/hour charging power.
'08 Sierra 5th wheel bunk house
'04 F350 6.0L (bulletproofish now)
470ah GC2 battery bank, 500w Solar /w TS-45 Controller, 2k Pure Sine Inverter
Active Duty Army
