โApr-09-2015 05:12 PM
โApr-11-2015 09:40 AM
โApr-11-2015 07:53 AM
Gene&Ginny wrote:pennstaterv wrote:The auto changeover and regulator on RVs has 11" W.C. output to feed the stove, fridge, and furnace. You need to remove the regulator from the grill and use the low pressure from the RV directly to the grill. I did that with my Coleman Roadtrip grill. I have a long hose from my grill that I plug into the existing quick connect on the trailer. No messing with extra tanks or high pressure connections.
... my propane griddle came with a regulator that has an output pressure of 11" W.C. and 95,000 btu. ....
โApr-10-2015 10:15 AM
gotsmart wrote:GASMAN6674 wrote:
If your grill,hotplate, griddle etc runs on 11"WC (approx 6.35oz) then go for it. Most of the "portable" grills use the disposable bottles and the fixture that it screws into on the appliance is the regulator (usually has the flame adjustment on it) If your grill has a conventional regulator or has individual burner controls you should be able to remove the oem hose and connect to your RV's quick disconnect.On the disposable bottle units unless there is a "factory" kit to convert to low pressure it is best to tee in ahead of your RV's regulator and use the existing appliance hose.
Hmmm. I have an 15+ year old Coleman camp stove (burner on the right, grill on the left) and a Stay-A-While Deluxe adapter on my MH. I plug the Stay-A-While's gas grill hose into the Coleman grill where the propane bottle would normally go. It works perfect as is - no conversion kit needed. The flame height and heat output on my Coleman is the same as if the grill was running on a 1 quart bottle.
โApr-10-2015 08:18 AM
โApr-10-2015 07:11 AM
pennstaterv wrote:Gene&Ginny wrote:pennstaterv wrote:The auto changeover and regulator on RVs has 11" W.C. output to feed the stove, fridge, and furnace. You need to remove the regulator from the grill and use the low pressure from the RV directly to the grill. I did that with my Coleman Roadtrip grill. I have a long hose from my grill that I plug into the existing quick connect on the trailer. No messing with extra tanks or high pressure connections.
thanks... that was my next question --- this is exactly what I want to do
โApr-10-2015 07:03 AM
โApr-10-2015 06:18 AM
โApr-10-2015 05:43 AM
โApr-09-2015 06:49 PM
Reese Dual Cam Straight Line HP Sway Control
โApr-09-2015 06:44 PM
โApr-09-2015 05:58 PM
โApr-09-2015 05:21 PM
โApr-09-2015 05:18 PM
