Refurb / Repair 2000 Travel Supreme
DonJon99
Hi all. Newb here. Just purchased a 5th wheel for the 1st time. Travel supreme express 2000 38'. Had 3 other bumper pulls in the past. Really like the trailer a lot but it needs some work. Some problems I found while inspecting it ( with no help from the lying sellers lol) and some I found after a few days (I guess they failed to mention). I want to start a thread to go through the process of my "rebuild". I have to replace roof, two rotten wall sections, toilet leak, some cabinet frames, and what ever else comes along. I will have lots of questions along the way and maybe teach someone else how to do something they don't know.
I'll start out with some pic of my 5er.
Click For Full-Size Image.
Click For Full-Size Photo.
1st thing thing I'am doing is trying to stop the leak with a temporary fix till I can get it in my shop. I couldn't see any places that looked like they would leak till I removed the old caulk. The caulk was very easy to peel off and I realized the water had seeped under it to get inside.
Further inspection reviled the hidden part of the roof that looked new (nice off white color and thick feel) the exposed part was just rubber (black color and very thin) most of the roof looked like it was flaking. Kinda looks like old cool seal someone put on it. Hard to see but the dark spot in this pic is the hole I found and the rotten wood showing. 1/4" hole that was under the caulk. Also, there is a 1/2" gap between the trim piece in the back and the trim down the sides.
Got to looking at that trim gap and found this. Whole back "cap" of tt was separating from body. Only explanation I can give is maybe the wet wood inside swelled up and pushed it away.
31 REPLIES 31
westend
I understand, it's a long process to get everything done. Give yourself a slap on the back for getting it completed.
'03 F-250 4x4 CC
DonJon99
Wow. It's been two years since this. Time flies. About the time of my last post I found that my main slide out had a rotten corner. Both slide out headers that supports the roof were rotten mush. The front of the Rv had a leak in both corners of the roof and rot in the walls to floor in those areas. I was so disgusted. My job ended about that time so I worked 30 days straight on this mess for 14 hours a day. Got it where I could move it down road. Took it from tx to al to go on another job and didn't work on it till November. Spent about another two months pitiling on the insides. Got it ready to live in about February of 2015. Been in it since. About 1-1/2 years now. Will try to post my progress starting where I left off when I get some internet service.
DonJon99
The part I was dreading is now over. Glueing down the sides. Couldn't figure out which way I wanted to do it. So I finally decided to use liquid nails and staples to install the luan to the frame. LOTS OF STAPLES. Like every 2". Worked great.
From here I went ahead with the contact cement. I used 2 whopping coats and just beat it down with a rubber hammer. Seemed to work pretty decent. Couldn't really find a way to clamp the whole area down. There are more expensive products that I could have used, but I took the cheap route at 35.00 per gallon vs 170-210.00 per gallon.
EDIT. Now that it's been glued down a few days with the contact cement. Most of it seems to be holding, but there are a few small areas thAt are not holding good. Not sure if I would recommend it. Good enough for me, I see no bubbling or anything and I'll reshoot the loose areas with some liquid nails.
DonJon99
Got a couple of weeks to work on this "wreck" while in between jobs so should be moving a bit faster. Got the rafters back in yesterday. With the roof decking.
Today I mostly scraped and cleaned off the fiberglass on both sides to prepair for glueing it back down. That took all day. Glued down one small spot of fiberglass for a test run. Hopefully by tomorrow I will have the wall exterior complete. Hope so, it's a pain.
DonJon99
@Westend
Thanks for that advice. I've been trying to keep the same measurements while I'am rebuilding but some I don't have. Since you told me that, every time I add something or screw it down I put the cap on just to make sure it's right , lol. I have it suspended just behind the trailer and can easily swing it over when needed to make sure everything is right. Got it held up by 4 ratchet straps. One set is close, to move it in and the other set is a few feet back to move it out of the way.
Since the last post I haven't had too much time to work on it but I got the 2 walls tore out and replaced. Also tore off the roof that was bad. Took out 2 rafters and about 45" of roof decking.
westend
DJ, got a tip for 'ya. When you're rebuilding the walls, make sure the whole back framing structure is the same square attitude and dimension as the back wall cap. There was a guy on the forum, not too long ago, that rebuilt the framing in the front wall and adjacent roof. When it came time to reattach the formed front cap, it was different, dimensionally, than the wall and roof framing (one was out of square) and he couldn't make it work.
Measure four times.....cut a lot.:B
'03 F-250 4x4 CC
DonJon99
Thanks! I found some 1" foam board which seams to be rare around here. R-6 Jammed it in between the floor joists to block some of the air that seeps into the cargo bays. Then installed the decking. Glad that's over with. Onto the walls.
Cummins12V98
Looks like you are doing a great job. Did a rebuild on a 25' Prowler 5th wheel years ago. Lots of rot! Good call on the Kilz.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
westend
Attaboy, nice play on the paint!
'03 F-250 4x4 CC
DonJon99
As of now, totals on cost are:
Storage: 185
Roof materials: 875
Wood paint foam screws: 309
Total: 1369.00
DonJon99
Got the compartment floor and framing for main floor back in. Put kilz on everything just for good measure.
DonJon99
Finished tearing out the lower floor that went to the storage bays.
Started the first part of the rebuild process with these small curved pieces.
DonJon99
More tearing out. Just going slow with it to make sure I put it back together right. Taking out anything I see that has water stains and is easy to remove. I was getting a bit overwhelmed with it all so decided to focus attention to rebuilding the floor and working my way up. Probably the only approach anyway. I was pulling some type of "caulking" from under the trailer. Sealed up the bottom "skirting". This stuff pulled off fairly easy, acted like a rubber band but I could hardly break it. Anyone know what type sealant this is?
DonJon99
@westend. Ya I looked at that a while ago and saw what you did. Just checking the options.
Was thinking of using 2- foam type boards with a small air gap between them. Biggest concern is the moisture. Here is what I found at lowes here.
Blue board 3/4=4R 1/2-3R
R-max ( if I remember right it had foil on one side)
1/2------5/8------3/4
3.2r-----4r--------5r
White foam with foil on one side- need 3/4" air to get full R value.
1"-----------3/4----------5/8---------1/2
Foam--------------3.8----------3------------2.5---------2
Foil-----------------.17----------.17----------.17---------.17
3/4" air gap------2.8----------2.8----------2.8---------2.8
Totals-------------6.82---------6------------6.5---------5
I'am thinking either of the 1st 2 at 1/2" then 1/2" air gap then the white foam at 1/2" would give me roughly 8R. I don't know...just thinking out loud.
Did some more demo today. Forgot to take pics. Here is one when I started, after I removed the back
