Removing front CRT TV from Tiffin Open Road
beaubeau
Hi! I just bought a used 2008 Allegro Open Road.
I'd like to replace both CRT TVs with new smart TVs.
I think I can figure out how to remove the bedroom TV, but the front one has me flumoxed.
I don't see any screws holding the wooden bezel to the upholstered overhead cabinet / bulkhead.
Is that bezel just mounted with friction fittings like an automotive dash? Can I just pry it off? That doesn't seem like enough strength to hold that big TV. Or maybe the TV is secured inside the cabinet?
How can I get that old TV out?
Thanks much,
Chip
Chip & Nancy (and our furry pack). 2008 Allegro Open Road Freightliner.
14 REPLIES 14
Johno02
Post a picture and we will tell you how!
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
beaubeau
It was heavy alright! But I put the new TV box and styrofoam in the floor so I didn't have to hodl it for as great a distance -- no pains at all ๐Ÿ™‚
Now to decide how to mount the new one ๐Ÿ™‚
restlesswind
We all knew that you could do it !
Those thing weigh a ton. No sprains, strains or pains...we hope.
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
beaubeau
I finally got it out! Once I got the stripped screws out, the woden bezel / frame slid out.
That left me with a TV held into the cabinet by 2 long wood screws, drilled through the upper corners of the TV chassis. No fancy mounts needed back then -- just 2 big screws ๐Ÿ™‚
ADAD437
that and a board in front of it is all that was holding mine. just lift over the little board and pull out.
James,Gail & Pancho
2005 georgie boy Pursuit
๐Ÿ˜›
beaubeau
Well, I took the 2 screws out on the passenger side but the 2 on the driver's side were stripped -- so I don't yet know what's back there. But ... with those 2 out, I was able to pull the passenger side of the wooden frame / bezel away from the TV and shine a light down that side. I don't see anything that's actually holding the TV in the cabinet. I'm sure there has to be - I don't think that frame alone would be enough, but maybe I'm wrong. The TV still feels very solidly mounted even with half the frame pulled away. I'll be back in there once I buy some stripped screw extractors...
ADAD437
it would be interesting to know what you find.
James,Gail & Pancho
๐Ÿ˜›
beaubeau
That sounds great! I'm going to be back in the RV this evening and I'll take a look. Thanks very much!
sdianel_-acct_c
this might help: from an old post: BCooke has it right. Open the left and right side compartments flanking the TV. The screws in question are close to the front frame of those compartments and can be hard to see without putting your head part way into the compartments. Although the screws are quite long, they only need to be backed out about 3/4" and the wood frame around the TV can be pulled out. the remote sensor receiver has a plug that easily separates. Once the frame is removed, a flashlight will show you the screws holding the TV to the wood frame behind the TV. There should be 2 screws on each side at the bottom, and one each side near the top. Use caution as the flat screen is heavier than it appears, and the wires may need to be disconnected before you can set it down on the dash. A helper is quite useful.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
CA_Traveler
ADAD437 wrote:
look for some little wooden plugs and pry them out. screws behind them.
They can be finished and not obvious.
2014 Grand Cherokee Overland
Bob
w4phj
Once the front CRT is free to lower, hire 2 high school line backers to
lower it down. Worked for me.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
Johno02
Post pictures. No idea from here what it looks like, have never seen one. Mightbe able to help is we see what you are talking about.
ADAD437
James,Gail & Pancho
๐Ÿ˜›
USAFBILL
Call Tiffin for the information.
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
