I have an 2013 R-Vision Super Sport 25 RKS with a slide. Wiring runs from the main part of trailer to the slide. When they built it,, they put the bracket that holds the wiring on the slide in the wrong place. It hit the main frame when the slide was closed. It even broke the 3 inch wide plastic support before I caught it. I put an aluminum plate where the bracket was before and moved the bracket down so that it cleared the frame when closed. Hope the pix I am posting with this makes it clear enough to understand.
