Replacing shower wall paneling
jbpatton
Remodeling Trailer due to water damage need to replace Shower wall what did you use for the shower stall it's going into a 1971 Holiday Rambler
2 REPLIES 2
doughere
I got an inexpensive tub surround kit at HD or Lowes (don't remember) less than $100.
Kit was 5 pieces. two ends, a middle, and two corner shelf/brackets. Cut to fit with a sharp utility knife, and glue to walls.
Has held up for many years.
Doug
westend
I'd use Fiber Reinforced Polyethylene (FRP) sheet goods. I used it for the ceiling in the shower stall of my Starcraft and it's worked out well. It's sold at the big box stores.
'03 F-250 4x4 CC
