Apr-24-2022 10:14 AM
Jul-07-2022 10:14 AM
valhalla360 wrote:It also can turn into a large, heavy, flying missile in case of an accident if it's not secured. That's not nearly as important in a TT/5er.stripit wrote:
We just removed the sofa from our rig and it was held down to the wooden flooring with lag bolts. Then there were large bolts for the seat belts that went into steel framing.I would use some way to secure the unit to the floor.
Probably bolted down because you have a MH and with seatbelts, it's considered at least technically as seating while driving.
Apr-25-2022 05:38 AM
Apr-25-2022 03:41 AM
jdc1 wrote:
A jacknife sofa is not the same as a regular sofa or recliner. They are top heavy. They need to be bolted in place. The plywood subfloor in slides is 1". Use lag bolts. The framing under the plywood is usually 1" also, so, if you penetrate the plywood, do so no more than 3/4".
Apr-24-2022 07:57 PM
Apr-24-2022 06:48 PM
OP is asking about a 5th wheel, only our kitchen table is secured, chairs, futon, recliner all just sit there..
Apr-24-2022 06:44 PM
Apr-24-2022 03:31 PM
Apr-24-2022 03:10 PM
Apr-24-2022 01:33 PM
Apr-24-2022 12:00 PM
Apr-24-2022 10:48 AM
