โJun-17-2014 06:02 AM
โJul-12-2014 01:53 PM
โJul-10-2014 06:53 PM
โJul-10-2014 06:31 PM
โJul-10-2014 09:15 AM
โJul-10-2014 08:33 AM
vlopddap wrote:
Hi! I wanna share the final result of my LED TV installation. I finally go ahead with the modification of a LCD computer monitor mount to mount it on the countertop surface instead of a true wall-mount. Basically the monitor mount have the same 3-ways adjustments than a true wall-mount bracket, but it's held by the desk surface instead of the wall.
I begin by cutting the large (and VERY thick) "U" shaped clamp bracket... using a handheld grinder with a cutting wheel. After that I drill three holes in the now flat bracket to screw it on the countertop right flush to the wall. The rear two screw are #10 2 inch long screw and they gone through the countertop surface into the solid wood frame structure of the wardrobe. The front screw is a 1-1/2 inch bolt that goes through the countertop surface. Trust me, this is EXTREMELY strong especially for a 8-9 pounds LED TV! The monitor mount come with cable management clips, but the cables are pretty thick so I put some zip-tie too be sure...
I use a premium 3-ways LCD computer monitor desk mount from Monoprice (18$) and the TV is a 19 inch RCA LED TV from Walmart (99$). I also use a Philips media player where I connect one of my 2.5 inch portable 1 TB HDD with 200+ DVD disc image inside.
Only remaining part is to install a small clic strap (like child seat) on the wall to ensure the TV are not moving when travelling.
Here's a few pic, sorry for the actual quality, it's pretty dark inside the RV even with the new LED dome lights!
โJul-10-2014 08:24 AM
โJun-21-2014 07:40 PM
โJun-21-2014 09:02 AM
vlopddap wrote:
I have 5x LED/LCD/Plasma TVs at home and I have WD-TV Live devices on all my TVs and they are all networked using WiFi. I have a media server PC in my basement where my 800 DVDs are ripped (6+ TB hard drive space). I also have about 100 Blu-Ray rips. I still have the 800 original DVD inside large Rubbermaid bin inside my exterior shed...
โJun-18-2014 10:45 AM
โJun-18-2014 04:41 AM
vlopddap wrote:beemerphile1 wrote:
I would look for a different location, I hate looking up at a television. Ideally it should be at eye level when sitting in your favorite seat.
Since it's only a 16 feet trailer, this is the only suitable place for TV mounting. I agree with you, I dislike to watch TV from that angle too, but this is the only option...
โJun-17-2014 06:57 PM
โJun-17-2014 01:01 PM
โJun-17-2014 12:42 PM
โJun-17-2014 11:36 AM
