โApr-30-2017 07:02 PM
While the purists will probably look at what I have and cry, others will admire a camper that is still around and kicking in one form or another with some history behind it.
I have what was originally a Westholt tent camper. What info I can find says that they were made in the early 1960s. Mine has a California registration tag next to the manufacturer nameplate.
The person I bought it from said that the camper was originally used for years as a camper in northern Minnesota and Wisconsin. It was bought in the early 2000s, with the canvas falling apart, by an alcoholic electrician. He used whatever materials he could get, plywood, some 2x2 and 2x4, and a pickup topper, (He also used about 5 different heads of screws.) to built it into the form that I bought it in. He lived in it for many years in the Duluth MN/Superior WI area.
The guy I bought it from, a general contractor, had gotten from the electrician and had been using it as a storage shed. He was hard up for money and so was selling it. We had to connect my pickup to his in tandem to pull it out.
I did some minimal fixing and used it as a camper for a year, but found many issues which can be summed up by the fact the electrician used fiberglass insulation and the seams were now leaking. Just about all the wood was in some state of rotting away. The only real option was to gut it and rebuild it. Spring cleanup is this week where I live, so I got my dad and brother to help me get the pickup topper off and then towed it around to the front to demolish the wood and toss it onto the berm.
I got just about everything stripped out except for the bottom flooring. That too has gotten wet over the years and is of questionable structural integrity and will need to be replaced.
Once I have the floor out, my plan is to pressure wash the remaining fiberglass insulation and other stuff off of the inside shell. I'll then make a frame of 4x4s to make the top rigid and add some extra height. I'll then re-use the pickup topper that I got with it for the roof. Going by my math, I should have about ~50" of interior headroom. Plenty of space for a little sleeper camper for one or two people. The door is big enough to crawl into and out of.
I don't plan on insulating the floor, since vertical space is at a bit of premium. I may add half an inch to an inch on the metal sides and cover it with automotive carpet. Not completely sold on if it is worth even trying to insulate it vs just carrying some extra blankets. The roof will be the fiberglass pickup topper.
It will look like ****, but will be a nice basic box that you can sleep in. That's all I'm really looking for.
โMay-09-2017 08:20 AM
โMay-09-2017 06:52 AM
โMay-08-2017 08:47 PM
โMay-03-2017 05:57 PM
โMay-02-2017 10:55 PM
โMay-02-2017 09:56 PM
TNGW1500SE wrote:
50 views and no comments? Ok,,, I'll do it.
Sorry but,,,,,, After looking at your pictures, I am wondering what you're thinking but more than that, I'm wondering what your neighbors are thinking.
DrewE wrote:
The floor may well be held in by the bolts and nuts, maybe underneath a thin top layer of subfloor. It could also be glued down to the frame, though that's a lot less likely if it's original 1960's construction. You might be able to get some clues on the construction by examining the bit exposed where the door opens (maybe with some exploratory demolition from that point).
DrewE wrote:
I would suggest you rethink your structural member sizes. 3/4" plywood and 4x4 posts are going to be heavy for what I assume is a pretty light-duty trailer suspension. The posts, in particular, would be far, far stronger than is necessary for supporting the truck cap. 2x2 should be plenty, particularly with some diagonal bracing or skin to keep them from deforming under load. I personally would also forego using pressure treated wood for this, since it's not in ground contact and the pressure treatment chemicals can do unsavory things to people and a fair few metals. Much of the pressure treated wood, at least around here, is none to straight or clear or well-seasoned. (If you do use it, make certain you don't have any aluminum parts in contact with the pressure treated wood.)
It does sound like it could be a fun project.
drsteve wrote:
I'd tear it down to the frame and turn it in to a teardrop, as others have suggested. But whatever you do, lose that nasty old truck topper. It will ruin the looks of your hard work.
โMay-01-2017 05:34 PM
โMay-01-2017 01:07 PM
โMay-01-2017 10:37 AM
โMay-01-2017 09:02 AM
โMay-01-2017 04:52 AM
โMay-01-2017 03:27 AM
