Yet another thermostat upgrade question
alex800
I purchased non-programmable Honeywell thermostat and still confused on how to connect it in my Heartland Wilderness 3150DS.
The model of the new t-stat is RTH5100B.
There are 6 wires in my TT connected to Coleman-Mach analog t-stat. I decided not to install additional switch for Hi/Low fan operation to simplify the installation. I can always add it later as long as I can identify all the wires.
Here are the wires that are coming out of the wall.
Red
Yellow
White
Brown (Connected to Grey)
Green
Blue
I know I need to connect White and Yellow but Iโ€™m really confused about the rest of the wires. Some posts saying not to use Blue and Green others are saying not to use Red.
The new โ€“t-stat has the following connections:
Rc
R
Y
Not used
W
G
I would appreciate any help with this mod.
2011 Ford Expedition EL Limited w/Tow package & 3.73 Rear end
Equal-i-zer Hitch
2015 Heartland Wilderness 3150DS
6 REPLIES 6
Old-Biscuit
Nothing conflicting......
One is for a Dometic (DuoTherm) and one is for a Coleman-Mach
Two different A/C Units.......different wiring configuration
alex800
Looks like we have conflicting diagrams here but I will need to follow Coleman Mach diagram because this is what I'm replacing...
Equal-i-zer Hitch
Old-Biscuit
alex800 wrote:
newman fulltimer wrote:
coleman. honeywell
red.............red
blue.............not used
white,............white
green,............to high fan
yellow.............yellow
if you dont wasnt low speed tape off all other wires
Assuming Green wire to G connector and tape off Blue and Grey. Did I get it right?
Correct.......
Blue (12 neg) is not used and Grey is for low fan speed (would need switch to use Grey & Green)
downtheroad
I used this...(but also added the hi/lo fan option). Worked perfectly.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
alex800
coleman. honeywell
red.............red
Equal-i-zer Hitch
newman_fulltime
coleman. honeywell
red.............red
