ZEP with or without decals? Before or After?
dacostadesigns
I have removed the old decals from my faded 94 C-Class. I want to do the Zep treatment, but I also want to replace the decals. I am wondering if I should first put a few coats of the zep before the decals or should I apply the decals & then coat it. Anybody have any experience / suggestions?
20 REPLIES 20
8iron
I used the ZEP as a last resort last spring. No amount of polishing then waxing with a buffer would last more than a few months on my badly faded front cap. The local body shop was too busy to paint it before we left on a long trip so I tried the ZEP...3 hours and 5 coats later the front cap still looks awesome. In my situation I had nothing to lose by trying the ZEP and I'm glad I did.
2014 F350 Lariat
2011 Sunset Trail Reserve 29ss
Skid_Row_Joe
I'd like to see some pictures of the Zep product /fails from those who say it /fails in those various states of failure, please?
royl
I agree on not using ZEP wax. At least not in the desert southwest. The sun causes the zep to peel off badly making your motorhome look terrible. I am in the process of removing it now and it does not come off easily even with the ZEP stripper. I wish I had never applied it in the first place.
Roy & Sabine
2000 Coachman Classic 27 RK Fifthwheel
1992 Dodge D250
Skid_Row_Joe
dacostadesigns wrote:
I guess, I was concerned that the decals would "over adhere" to the porous dry gelcoat, and that the decals would look weird if I applied zep over them, or have a bonding issue to the surface of the decals. I suppose, I could avoid applying the zep to the surface of the decals.
The Zep will go over the decals just fine. Just sponge on a coat every year to keep your unit and decals looking fresh. Apply decals to bare fiberglass, then sponge on a couple three coats of Zep, and you're good to go!
Chris_Bryant
If you're worried about Zep, you can always use PoliGlow- made for that use.
-- Chris Bryant
dacostadesigns
For my decals (on filon) I used a razor in a blade holder. I scraped about 1/4 to 1/2" of the stripe at a time. Dont try to remove the whole width of the blade at once, it will cause it to bite into the surface. A heat gun may help soften the vinyl, but I found it wasnt necessary. Then the best for removing the remaining glue was xylene.
I have a c class and did use a rubber wheel on the painted cab surface, but it is more of a PIA. It was messy and time consuming. It did work on the softer paint, but I cant imagine doing a whole rig with one - or several wheels. I still used the xylene to clean up the residue.
JimMartin
For the OP; I'd be interested in hearing more about how you got your decals off. I need to redo mine soon but I have an aluminum trailer.
Use a 3M eraser wheel on a cordless drill and a heat gun. I did a 34' Coachmen this way last year and it worked great.
2003 Georgie Boy Pursuit 35', V10 F53 Chassis
hershey
OFDPOS wrote:
Some have had a good experience with the zep others haven't.
I'm sure robatthelake and myself will get flamed here, BUT I totally agree with not using it !
Alot of times the gelcoat shine can be brought back with a good DA buffer !
Go on youtube and type in removing/replacing decals alot of good advise and of coarse some lame ...
I've never worked with the Zep before , but I would think you would still have to clean/prep the surface to put it on.
Doing that your half way there , might as well just put the decals on then put a couple coats of wax on and your done.
I could just see the Zep turning yellow or peeling after awhile !
Why do you think you would get flamed for having a different opinion? Buffing the old finish is obviously a proven way to get back to the original shine. My position is: Some people aren't able to use a buffer anymore and you can certainly damage the surface with a power buffer very easily if inexperienced. An orbital buffer might be a better way to go...slower, but still effective and alot safer. The Zep method is a safe way to achieve a really great shine also and most anyone can apply it. Preparation is the key to achieving success with the Zep application. Different strokes.......
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
4X4Dodger
There are plenty of really good Marine Gel Coat products out there that are good for your RV. Use them.
Gjac
My experience having used a machine buffer and the Zeps is try to bring back the oxidized gel coat surface first with a buffer. If you can't then use the Zeps. The Zeps will adhere to a rough surface much better than a smooth surface. It will want to peel and flake if the surface is smooth or applied to thick. Up until my MH was 16 years old I could still hand polish it with a lot of effort. Two years ago I applied the Zeps and it still looks good. Some folks in AZ for example say it is effected by the hot sun and will yellow and flake. Machine buffing is a lot of work to bring back the shine and you have to be careful not to burn through the gel coat. The front and rear caps have a thicker gel coat maybe .020. The sides especially older Filon are very thin, you can actually see the fiber pattern through the resin. You don't want to expose the fibers buffing the surface. My conclusion at 68 years old and two repaired rotator cuffs the the Zeps was easier. If I was 48 I would try machine polishing with a good cutting compound first then a polishing compound followed by a good wax.
robatthelake
I wish that I had taken a few photos,before during and after using the ZEP . Unfortunately I did not,but since I still have some of the Product I suppose that I could replicate the results for those who still think that it is the Cats Meow!
I will not be doing so on My Rig or Boat However. So give Me some time to find something unimportant to ruin!
To those who will tell You that preparation is the key to success ,They are quite Correct,but if You are going to go through the Hours of Prep time necessary to achieve a proper job ,why would You finish using a Product that was never intended to be used this way!
Yes it does Put a shine back on the Faded Dull Surface,but it is only a temporary fix for a permanent problem!
If You want a shiny paint job that will stand up to the elements ,have the unit painted with a good Clear Coat over the Base Colour!
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
hershey
The RMP or Zep application and success or failure is like someone buying a can of automotive paint and prep the surface and spray the paint on. One might end up with a beautiful shine and success, the next may end up with an orange peel mess with runs all over the place.
With the Zep application, its all about the preparation. If you don't get all the wax off before application, the immediate result will still be good but after a couple years, it will start to flake off. With proper wax removal the results are great. The beauty of the application is: if you aren't satisfied, the Zep removal product makes it duck soup to remove it and you can go back to whatever process you like. The remover works extremely well.
dacostadesigns
Rob, I have heard both pros and cons about the zep. I have seen "pro" pics and videos of the use of zep, and only hearsay of the negative results. Do you have pics of the negative results, it would benefit a lot of us since it is pretty popular topic.
As far as wax, Besides the amount of work it will take, I have tried a few spots and it seems to have little results, and actually what shine is produced only lasts a few weeks. Which is why I considered the zep. I used to detail cars professionally, so I have tried high speed buffing as well as da polishing. Maybe I will take another whack at it.
BTW, I have found the BEST cleaning for the fiberglass is the LA's Totally Awesome from the dollar tree. Probably strips all the wax off of the fiberglass, but it cleans much better than the TSP and Bar Keepers friend, with less scrubbing.
wildtoad
Regardless of what you do later, decals go on first. consider the ZEP as the base but you should follow up with regular application of a spray on uv protectant to keep the ZEP from deteriorating.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
