11' garage and 12'6" kayak, will it fit?
FireRob
Edit: problem solved. Thanks everyone!
Just looking for conformation that with the normal stuff attached inside the garage (happy jack bed and sofas) that a kayak that is 12' 6" long can be angled in the garage that is listed at 11" long. The model toy haulers I'm looking at have overhead cabinets/loft towards the front of the garage but nothing below so there is a little room for some upward angling as well. Is this a realistic expectation?
2016 Ram 3500 Cummins 4x4 CC Longhorn LB DRW 4.10's Aisin Trans Auto Lvl Suspension Dual 220 Alternators
2014 Ram 2500 Cummins Megacab 4x4 Longhorn (traded in)
2015 CrossRoads Longhorn ReZerve LTZ31SB
12 REPLIES 12
MartyMoose
When I take my double, I leave the sliding door open ( and secure it) and the kayak just extends into my kitchen a foot. No biggie, just don't forget to secure door open or against the boat.
2014 Heartland 305RW Road Warrior
2012 Ford F250 Lariat
DutchmenSport
darsben1 wrote:
Pythagorean Theorem will solve the problem
Nah! That's just too technical. If the Kayak don't fit, just get a bigger camper! Problem solved! :C
darsben1
Traveling with my best friend, my wife in a 1990 Southwind
FireRob
Bumpyroad wrote:
DutchmenSport wrote:
If the kayak is positioned diagonal (say) bottom left (back) corner to top right (front) corner, why can't the lower end be at the front and the higher end at at back? Unless you have cabinets that go all the way to the floor? = front (bottom) right to back (top) left?
yep, my question also.
bumpy
With the fictional problem I have presented, I don't see why that wouldn't work. I don't even have the kayak yet. It's a wedding anniversary gift from my wife and I'm expecting delivery of it in the next couple weeks. The toy hauler doesn't even exist yet either. I'm trying to plan ahead for a future purchase and was just getting my ducks lined up before hand.
GottaRunGottaCa
I carry one 14' and two 11' kayaks in my 10'3" garage, the two 11' on the floor and the 14' catty corner
:C
2016 F350
2019 Heartland Torque TQ-371
Bumpyroad
bumpy
DutchmenSport
Bumpyroad
if you put one end on floor under cabinets I don't think you will lose that much length???????? if any
bumpy
Old-Biscuit
FireRob wrote:
Biscuit I was hanging with you for the top half but you lost me at AC= sqrt
I think we are saying somewhat of the same thing you just came to a more conclusive way of getting there.
AC is the diagonal distance from one corner to opposite corner of a rectangle
Flat rectangle 8' X 11'....diagonal is 13'7"
AD is the diagonal distance of that AC distance to opposite corner of the box
Rectangular box 8'W x 11'L x 8'H.....diagonal from bottom corner to opposite top corner is 15'8"
8'H used is just an assumption on height of TH garage.
Taller would allow for MORE distance
FireRob
FireRob
Found a nifty triangle calculator and found I can put the rear (stern)of the kayak against the back left corner of the garage and angle the nose (bow) 28* to the right and it will have to be about 6' away from the left wall. All this assuming the kayak was as thin as a straight single line.... but these garages are almost 8' wide inside right? Should fit easy peasy?
Old-Biscuit
The diagonal measurement of an 8'W x 11'L rectangle is 13.6' (13'7")
IF height is 8 foot then diagonal measurement from bottom corner to opposite top corner is 15.7' (15'8")
AC= sqrt(AB^2 + BC^2)------Square root of (8x8 + 11x11)----13'7"
AD= sqrt(AC^2 + CD^2)------Square root of (13.6x13.6 + 8x8)---15'8"
With overhead cabinets you lose at lot of diagonal length
With jack bed/sofa .....may be a obstruction
12'6" MIGHT fit
Take a 25' tape measure and measure distance from top corner under overhead cabinets to opposite bottom corner
