โJun-04-2014 02:27 AM
โJun-04-2014 06:24 PM
โJun-04-2014 03:14 PM
kaydeejay wrote:Jeff & Claudia wrote:Sooner the better as I figure you are 1400# to 1600# over GVWR. Your brakes will be tested as they are stopping MORE than they are certified for!kaydeejay wrote:wirenutz wrote:Not so much the towing capacity, but I'm pretty sure payload (or even GAWR) will be an issue.
congrats, I'm sure your Duramax/Alison combination will do great, but your 3/4 ton towing capacity might be pushed to it's limits
With my actual weights for camping in regards to payload we are right at max, slightly below GAWR, and about 1500 below towing capability.
Once its time to purchase a new truck it will be a 3500.
Loaded halfway to GVWR you will have 2800# of pin weight, plus occupants, hitch, fuel and other stuff. If you are at GAWR you have added approx 3400# to the truck on the rear axle alone.
SOME of the extra weight will be on the front, hence my swag of 1500# (+/- 100#).
If your truck is 4WD your "official" payload may be under 2000#.
You really need more truck.
โJun-04-2014 11:06 AM
โJun-04-2014 09:29 AM
โJun-04-2014 07:50 AM
โJun-04-2014 06:31 AM
โJun-04-2014 06:28 AM
โJun-04-2014 05:59 AM
โJun-04-2014 04:32 AM
โJun-04-2014 03:26 AM
โJun-04-2014 03:25 AM
