2000 F350 Brake Controller
Artum_Snowbird
Hi again,
Looks like I need to install a brake controller into my truck and not sure where to put it.
I could mount it facing upward on the panel below the little cubby
hole and screw the mounting bracket into the plastic there, or I could put it into the cubby hole perhaps.
The power plug in is right behind this spot.
What models do you recommend for a 9000 pound fifth wheel and where did you put your controller?
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
9 REPLIES 9
rattleNsmoke
I screwed my Tekonsha P-2 into the ashtray lid. Perty much where you other guys mounted yours, just a lil' to the left.
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
cpaulsen
My controller is mounted just to the left of the ash tray on my 01. I have the phenolic pistons....never had a problem.
cpaulsen
jerem0621
LOL.. I had the Older brother.. Tekonsha Voyager.. same truck.. same spot!
Just need to be able to grab that over-ride lever if needed.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
Artum_Snowbird
Alright then.. all you guys with the same truck. Is anybody using phenolic pistons in their F350 brake calipers. It seems to be the most popular thing for a piston to seize in the caliper, and maybe the phenolic instead of the metal pistons would work better.
Mike
Brockinfla
2003 F350 same controller same spot. Works like a champ
Artum_Snowbird
Convinced me.. looks like I will be buying a P2 tomorrow and plugging it in.
Mike
shadows4
bfast54 wrote:
Wow....I have Basically the same controller....in basically the same spot,,
2000 Ford Superduty,Crew Dually.......Works fine there for me.
X2 I have a 2003 F350, same controller and basically same spot!! Works for me too.
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
bfast54
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
SH
This happens to be a Tekonsha Prodigy but there are many good controllers to select from.
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo 🙂
