2007 5th wheel Chapparral 267RLS discharge confusion
focstay
Hello,
My newly purchased unit has a 1-1/2 discharge line which I suspect is the grey water.
The large dia. 4 inch or so, which disappears forward a few feet and is across from the toilet. This is likely the black water.
They join to one discharge.
On my last unit I emptied the grey water tank through the black tank.
I'm not sure how to do this as there is a pull valve on each line. It appears to empty each tank separately.
Can anyone clue me in?
yatscoffbooks.com firefighter fiction
4 REPLIES 4
ChuckV1
If you look at the handles one will be black and the
other gray. The small line/pipe is the gray water and
the larger is the black water. As the OP stated empty
black 1st and gray 2nd
1492
Moderator
Moderator
Moved from Forum Technical Support
Old-Biscuit
Hook up sewer hose to that 'common' 3" line
Open black tank 3" drain valve
When black tank is empty-----------use flush connection on side of rig to flush black tank.
Close drain valve
Open grey tank 1 1/2" drain valve
Drain grey tank
Close drain valve
Add some water back into black tank......2 full toilet bowls flush is good. Keeps bottom of tank wet
ScottG
Empty the black first and then open the valve to the grey to rinse the hose out.
