2008 Hitchhiker II LS structure?
Njmurvin
Does anyone know what type of structural components the 2008 Hitchhiker II LS has? Is it aluminum framing in the walls or wood? Same question regarding roof structure? I'm considering a 26.5 RLBG and I can't find anything definitive about the materials used in its construction (aside from the Blue Dow insulation). I'm guessing it's wood because the mfrs usually brag about aluminum superstructures. I realize it's quality built regardless of material. But I had a bad experience with a leak in a wooden framed unit - so I'm a bit gun-shy.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
7 REPLIES 7
filrupmark
They used wood because it doesn't conduct the cold and moisture to the inside. Hitchhiker built excellent trailers. I think the ls is aluminum walls as stated by Old biscuit.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
JIMNLIN
check out nuwaowners.org forums for much more on any HH II units.
Old-Biscuit
Njmurvin wrote:
All I can see from the archive info is "Panel Core Vacu-Bonded Sidewall". Are aluminum studs part of this construction? What am I missing?
Can't find it any more......use to be an cross-section exploded view of structure of 5th wheel showing roof trusses, sidewalls, flooring, insulation etc etc.
I have a 2007 II LS (LITE SERIES)
We FTd in it for 7yrs
It has aluminum framed sidewalls that are filled with the Dow Blue Insulation and interior/exterior walls are glued to studs under vacuum.
Roof is 2X4 wood trusses overlaid with plywood
Subfloor (1" OSB) is laid down on top of 5vr frame
Need more details.....contact NUWA
Njmurvin
Old-Biscuit
2008 HitchHiker II LS........has aluminum wall studs and 2X4 wood roof trusses.
2008 NUWA II LS Archive Info
jnharley
There is some wood in our aluminum frame so things like the awning brackets can be attached. Our roof rafters are wood and I believe NuWa has a unique way of constructing and attaching the roof. If you have any questions, give Kansas RV (aka the old NuWa factory) a call or look on their website. They are very helpful people and should be able to answer any of your questions.
2015 Dodge Dually
2012 NuWa Discover America 355CK
DutchmenSport
Click here for more details.
