Sep-18-2016 12:47 PM
Sep-20-2016 08:52 AM
NHIrish wrote:
I had a 2010 and there were issues with rusting screws in many areas. Not an uncommon problem with Cameo. Having said that, I also had a caulking leak in the front cap and the rusting screws on the underside were a sign.
Having said that, the construction is robust and unless you have other signs of a problem I would not let that one issue be the deciding factor. One of the few brands that used exterior plywood. If you do buy it, make sure it has heavy duty shackles with greaseable fittings. They did cheap out on that and those rigs will suffer a shackle failure with enough miles. Don't ask...but it is an inexpensive upgrade best not done when you get stuck in Amarillo.
Sep-20-2016 05:37 AM
Sep-19-2016 06:42 PM
Sep-19-2016 12:52 PM
On each on the caulking on the side around the front cap was cracked and the screws at the bottom around the pin box area are rusted.....water leak?
Sep-19-2016 10:45 AM
Sep-19-2016 05:42 AM
Sep-19-2016 04:57 AM
Sep-18-2016 01:09 PM
