225/75/15 maxxis 8008 and the new goodyear endurance weights
Wills6_4_Hemi
I have given this some thought due to recent post that I have posted in. For the record I have never had a maxxis failure or personally know anyone that has. They are superior to all other trailer tires at least till maybe now. one thing I noticed about the maxxis is they are heavier that other 10 ply e rated tires which in makes me think they are just more robust. I have searched this morning for the weight of the maxxis and the new goodyear endurance and my smart phone is not cooperating lol. So do any of you know or can find the weight of the 225/75/15 10 ply e rated for each? If so please post. I have decided to be open minded for my next purchase in the next couple weeks and the heaviest tire may sway me. Thanks, Will
35 REPLIES 35
Me_Again
eHoefler wrote:
I have run 225/70R15C Maxxis LT tires on a work trailer for over 10 years, never had a failure, trailer runs loaded 100% of the time, weighs in at 7K+, I actually wear them out every 2-3 years
https://www.maxxis.com/catalog/tire-227-104-bravo-series-ue-168
That tire is similar to the Goodyear Cargo G26 225/70R15 LRD rated to 2470 lbs at 65 PSI.
Neither of these is a ST tire, which this thread "was" about. Both have good records for service on RV trailers "if" they meet the weight requirement and one is OK with a slightly smaller in diameter tire. Chris
Cargo G26 with 13/32" tread depth
Bravo UE-168 with 14/32" tread depth
Wills6_4_Hemi
pretty much my experience which is why maxxis is what I'm going with. Next set however I will re visit the goodyears and give them a little more time to prove themselves but they do seem promising.
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Wills6_4_Hemi
Cummins12V98 wrote:
OK, I am sure there are SOME failures. But i have heard ZERO issues on the RV Forums I have looked at. Now when you talk failures you need to be sure it is not a "road hazard" failure.
A guy did post somewhere a "failure" but it looked like a puncture and later he said it was.
And I have had zero failures/problems with maxxis but there have been failures. NO product especially tires of any make have a spotless record. One persons experience is never enough to make an educated guess at. That's why they have things called surveys and reviews. Glad they have worked for you and my decision has also made
Cummins12V98
Wills6.4 Hemi wrote:
Cummins12V98 wrote:
The Endurance has been out for over two years now. They have a spotless record! I run them on my heavy salt water boat trailer.
There have been several Maxxis failures reported.
GY does have a great warranty.
not exactly true I found several failures on a web search, anything man made can and will fail I just like to lower my chances.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Wills6_4_Hemi
How about a link or three?
Chris
not smart enough to post links but on my dumb phone they were easy to find. If you think nothing every fails I have ocean front property I'll sell you in Arizona lol.
garyp4951
Take your pic of these.
https://www.etrailer.com/dept-pg-Tires_and_Wheels-sf-Tire_Only-tw-Load_Range_E-pc-15_Inch.aspx
Me_Again
Housted wrote:
Bridgestone Duravis R250 LT235-85-r16 weigh 59# each
Just sayin...
Housted
Not made in a 15" model. I have used the R250 and XPS Rib, two of the best tires for 5200 and 6K axles. I actually liked the R250 better than the Ribs. 6.5 years with Ribs and 4 on R250 before selling that trailer. Never a problem. Seldom added air!
Chris
Housted
Just sayin...
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
Me_Again
Chris
JIMNLIN
Did you miss a 'not" in there somewhere? Chris
๐Ÿ˜ฎ Good catch...how about a "wouldn't" ๐Ÿ™‚
cummins2014
You better look again, hardly spotless. The Endurance , being out such as short period of time has had at least one report of failure that I read on the Montana forum.
I know you like pushing those expensive Goodyear tires, but they have been far from spotless, the G614's are great example of that. Great warranty, just about have to be with the damage from blowouts they cause. The G614's especially, and have been well documented on their failures . I think in the long run the Endurance is going to be a so so tire.
Its too bad Sailun does not have their RV tires in a 15". Spotless is the Sailun S637's ,and their Terramax truck tires .
Wills6_4_Hemi
ScottG
I have personally had a Maxxiss suffer a tread seperation. It was replaced under warranty. No overloading, no overspeed, pressure at max. They were great in the begining but now they are slipping.
I have GY Endurance on the new TT.
Me_Again
JIMNLIN wrote:
In the world of commercial trailers more tire weight is a good thing for best long term durability and reliability.
I doubt a rv trailer with the same tires/axles/wheels is any different.
The Maxxis ST8008 vs the Endurance gets posted a lot.
With over 30 rv website members reporting issues with ST8008s I sure would say their superior to any other trailer tire in the last 6-8 years. Complaints on haulers websites run about the same.
