28 footer is a single A/C enough for hot summers?
lacofdfireman
We have not owned a toyhauler for years but are looking at a new Sandstorm 271 G series. We have noticed that pretty much all toyhaulers in this size only have a single A/C unit. Is this enough to cool a unit this size? I know my 03 Weekend warrior came with dual air and an Ona. 5500. Pretty much all the ones we have looked at under 30ft come with a single air unit and an Onan 4000 generator. Is that generator enough to even run 2 A/C units if I wanna upgrade to 2?
2007 Forest River Georgetown 350 DS SE Bunk Model Class A V10
2013 Yamaha Super Tenere 1200 ADV Bike
MotoJug Motorcycle Hydration System
20 REPLIES 20
DutchmenSport
In our 31 foot Springdale TT with no slides, the original 13,500 BTU air conditioner did just fine. Never had a problem. But we did not camp in 115 degree climates either.
Fast forward. Our 35 foot Outback with 3 slides and the original 13,500 BTU air conditioner just could not keep up (even in milder Indiana temperatures). We swapped it out for a 15,000 BTU because our TT is 30 amp and it would have been a major rework with the wiring to get it converted to 50 amp. So we went with the 15,000 and it's worked great ever since, even with the 3 slides.
I have no clue how a second air conditioner will run on your generator. I have a small generator and it ran the 13,500 just fine. BUT the 15,000 won't start with the generator now. We never boom dock, but I have the generator just in case. Actually use it more for the house when we have power outages than anything else.
This would be my advise, get a single 15,000 BTU.
Strabo
We use a small swamp cooler attached to one of the rear vent doors on our hauler, works great with temps in the desert over 100. 65 inside with all windows and door open. On low speed too.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
time2roll
4000 is the listed minimum for a single air. Two would be marginal if they even start. But the new A/Cs are getting better so maybe a longshot but not impossible. Maybe 2x 13.5 high efficiency units. Or a 13.5 and smaller 9 or 11k BTU. Good luck.
If the RV is well insulated, parked in the shade, and you have a superior installation the single air should be fine. Reality is not likely as temps go 95+ if you want a steady 72 inside.
lincster
115F outside?
Not enough.
Onan 4000 will not run 2 units.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
dedmiston
Moderator
Moderator
Nice to see you back, Dave.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
donn0128
Desert SW not enough. Canada north, more than enough.
